Spartan question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-06-2013, 06:42 AM Thread Starter
Spartan question
Does anyone know if the regen can still be on after the deletes? Can u turn the regen on and off with a spartan after deletes, and if so how do you do that?
casey28643 is offline
post #2 of 7 Old 04-06-2013, 07:31 AM
WoodBoy's Avatar
You have DPF ON tunes and DPF Off tunes. If your truck still has the dpf intact, you select the dpf on tunes and if you take off the dpf you select the dpf off tunes, that is pretty much the dpf off tunes purpose is to turn off regen
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 7 Old 04-06-2013, 08:18 AM Thread Starter
spartan question
I am running the 275 tune with high lock. I have only tried the 275, 250, and 210. I deleted the truck before I put the spartan on it. I have never used the dpf on tunes. It blows blue smoke every so often when the truck is cold. Runs great no other problems, but the blue smoke. It last for 30 seconds to a minute.
post #4 of 7 Old 04-06-2013, 10:31 PM
benjamin24's Avatar
You shouldn't have a regen if the DPF is deleted. Running a DPF on tune with the pipe deleted would most probably throw codes.
The Blue smoke could be a couple of things, Regen shouldn't be one of them.
09 Lariat Ultimate/Spartan/
AFE SS Exhaust/AFE Stage II/
Weathertech/Cervinis/Toyo/UWS
benjamin24 is offline
post #5 of 7 Old 04-07-2013, 04:38 AM
KVB-R's Avatar
It's possible that it could be, though highly unlikely....like the folks here and in the other thread said, you would have issues if that was happening...
Spartan'd, 4" ICON Stage II, 35" Duratracs, XPD additive and M1 full synthetic
KVB-R is offline
post #6 of 7 Old 04-07-2013, 06:00 AM Thread Starter
spartan question
Thanks for the help. I will try to drain the oil level down to the max fill and see if that makes a difference. If that doesn't fix it I will take it in to the shop.
post #7 of 7 Old 04-07-2013, 06:07 AM
KVB-R's Avatar
Leaky injector I would assume.
KVB-R is offline
