Why delete a 6.4 and maybe not a 6.7 ? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-05-2013, 07:01 PM Thread Starter
pops250's Avatar
I have read on different threads and forums about 6.7 if going to leave it stock and 6.4 deleted . I was just wondering are the emissions on the 6.7 not as detrimental to longevity as they are on the 6.4 or is it just for warranty issues because the 6.7 are so much newer and most are still covered. I know both have egr and exhaust filters. Just different methods of regen , right ?
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #2 of 5 Old 04-05-2013, 07:17 PM
BIG Laing's Avatar
6.4's have more issues with regens then 6.7's.
6.7's have alot more power stock, even though the 6.4 internals are stronger. I have seen three 6.7 stories with bad or thrown connecting rods. I think alot of the connecting rod stories are connected to sub-par tuners though. So tuning a 6.4 = crazy reliable power. Where 6.7's have yet to prove them selves with alot of HP. (H&S has been working on the 6.7, with very immpresive results though, something like 800/1700)
The 6.7's have a smaller EGR since they added the DEF to help with the emmisions (SCR?). The EGT's during regens between a 6.4 and 6.7 are crazy different. 6.4's are sustaining over 1000* pre turbo EGT's during regens!
Plus with newer trucks IMO why void a warrenty?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 5 Old 04-06-2013, 05:03 AM
George C's Avatar
The difference is that the 6.4 uses 100% power killing and engine destroying EGR in order to make emissions. EGR reintroduces exhaust into the combustion chamber to actually cut down on power making (and NOx producing) by reducing oxygen levels. Very archaic to say the least.
The 6.7 uses urea as an after treatment (SCR) of the exhaust that does not involve the engine, thus allowing the reduction of EGR by over 40%. It's a great system that allows for more oxygen in the combustion chamber and a ton more power while still making emissions.
As for engines, the long block 6.4L is far superior, and if that platform would have had the luxury of SCR, it would have been spectacular stock. Since it is not in stock form, the best thing you could do for your overall engine health is to delete and shut down the EGR. Just by shutting down EGR makes the 6.4 a rocket.
Sent from AutoGuide.com App
2008 F-350
KEM 345 tuned.
George C is offline
post #4 of 5 Old 04-06-2013, 07:33 AM
WoodBoy's Avatar
The problem is emission laws get ahead of technology
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 5 Old 04-06-2013, 08:50 AM
George C's Avatar
Most cases yes, but in this case, no.
Europe has been using SCR for a number of years with great success. It's not new technology, and the technology has been available for quite some time. The problem is that SCR is more expensive and complicated, but works incredibly well and without involving the engine. American engineers thought that they were smarter and decided to use enhanced EGR instead of spending the money and installing something that was far better.
Navistar and Ram were the last to convert. Navistar was especially arrogant to the idea and thought they could make enhanced EGR work. They couldn't, and are currently paying the price with their stock in the toilet. Nobody wants to touch a MaxxForce engine, like nobody wants a 6.4l in stock mode.
Look for the next generation Super Duty to follow the class 8 Tier 4 market and run a higher dose of DEF, while turning down EGR even more. Safe 900 lbs of torque and clean record stock hp will be coming in 15'. The need to delete will soon be gone.
2008 F-350
KEM 345 tuned.
George C is offline
