Head stud install before gaskets go bad - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-03-2013, 10:34 AM Thread Starter
NVHunter83's Avatar
How much would it be to install (on average) studs before you have any gasket issues on our 6.4ls. I have a mini maxx, and I'm going to buy my exhaust and intake soon.
I'm only going to run stock power levels but all the stories of head gasket failure is scaring me. I drive my truck sensible, and don't want to hurt it.
I've read if you don't crank up the HP and don't hot rod the truck you'll been fine. I understand things break and go out but if i can prevent something from happening Im all for it. So how much would a pre head gasket failure stud install cost me?
Thanks
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #2 of 5 Old 04-03-2013, 10:41 AM
fordpwrstroke7's Avatar
I would drive it until something happens. You can drive with blown headgaskets for thousands of miles, as many people on this forum do before they realize what the problem is.
Drive it and keep about $4,500 in your pocket in case it does happen.
There are a lot of people that have the basic bolt on mods for the 6.4 and they have no issues. This isn't a 6.0 and the 6.4 doesn't have the amount of issues that the 6.0 does. Set your parameters for the tuner within safe boost limits (maybe 33 psi) and EGTs (1,400) and you can prevent most issues.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 5 Old 04-03-2013, 11:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Were you planning on doing studs 1 by 1? When i do studs i am going to take off the heads and have them magnafluxed and decked. When i do it i am going to do it right. I personally dont think the 1 by 1 thing is a good idea and is not as good as doing it right.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 5 Old 04-03-2013, 01:01 PM Thread Starter
NVHunter83's Avatar
No, I don't have any plan on doing studs and if I did it would be cab off, and all at once
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
post #5 of 5 Old 05-10-2013, 08:50 PM
Capt dong's Avatar
Quoted: 5 Post(s)
After a lot of reading I will be doing studs one by one. Haven't decided diy or shop. If your gaskets are good you will save a lot of trouble by doing it before they blow. You will spend less money on parts and labor. If you blow your gaskets it's a good chance that you will warp or crack your heads in the process and that will cost more to repair as well. Good luck.
08 F250 KR
08 F250 XL
Capt dong is offline
