turbo swap is it difficult - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-01-2013, 12:28 PM Thread Starter
Im swapping turbos is there alot envolved or is it better taking to a shop
rogco is offline
post #2 of 17 Old 04-01-2013, 01:19 PM
08stroker250's Avatar
There is a write up somewhere on Power Stroke Army.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 17 Old 04-01-2013, 01:31 PM Thread Starter
Swaping in a pair of elite tow power compounds and a airdog 2 . Is that a good set up
rogco is offline
post #4 of 17 Old 04-01-2013, 01:44 PM
Yes sir. The Tow Powers are a proven set of turbos.
Jeff Dodd
post #5 of 17 Old 04-03-2013, 12:52 PM Thread Starter
So I also picked up arp studs and oem head gaskets. Egr wastegate kit . So what levels can I set my boost defuels at to keep these new turbos and heads studs lasting forever and making good safe power
rogco is offline
post #6 of 17 Old 04-03-2013, 06:38 PM
WoodBoy's Avatar
What turbos?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 17 Old 04-03-2013, 06:40 PM Thread Starter
Elite tow powers
rogco is offline
post #8 of 17 Old 04-03-2013, 07:43 PM
WoodBoy's Avatar
You have ARPs correct? You are still on stock fuel correct? If you are going to put the wastegate on, I would set it around 68psi of backpressure. If you are monitoring with an H&S, your backpressure will read 68psi and thats where you want it to open. If you are running Spartan or something that reads atmospheric pressure, you would want to set it at 68+atmospheric pressure (ie: 14.7 @ sealevel). As for boost defuel, I wouldnt set a boost defuel
WoodBoy is offline
post #9 of 17 Old 04-03-2013, 07:50 PM Thread Starter
Yea stock fuel set up for now . Yes arp struds. And yes im running h&s . So there is a back pressure monitor on the h&s . So these turbo can handle the boost level and my engine without setting any defuels for boost
rogco is offline
post #10 of 17 Old 04-04-2013, 06:46 AM
WoodBoy's Avatar
Yeah those turbos will be fine, actually all of Elites turbos you dont worry about boost defuel. Wastegate would be your only concern and even on tow powers it isnt much of a concern
WoodBoy is offline
