Thinking about this for driveline vibration - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-31-2013, 08:33 PM Thread Starter
I'm in the process of talking via email with this place about a single drive shaft for the vibration from takeoff and to see if this will take care of the bounce from the rear at 50mph. I had zero issues at stock ride height and got the bounce and slight vibration at take off after lifting it.
Ford Truck Driveshaft
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 6 Old 07-28-2013, 04:54 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
U do this yet?
Big_Smokey is offline
post #3 of 6 Old 07-28-2013, 05:23 AM
WoodBoy's Avatar
I know the OP is an old post but I wonder if he ever dropped his carrier bearing any
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 6 Old 07-28-2013, 09:20 AM
matted2thefloor's Avatar
Exactly what I was thinking...driveline angle isn't right.
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #5 of 6 Old 07-28-2013, 11:58 AM Thread Starter
He actually never got back with me. Kinda disappointing.. Yeah i did play with the shimming. i had about an inch of shimming and still had it a little but was going in the right direction, which is way more than the 1/4" for every 1" of lift rule of thumb. I took it to my local mechanic and had some stuff done and told him about the issue. I had him change the u-joints and said I wanted it balanced also. There was a weight that broke off of it and had a ding or two in one of the shafts. After 4 weights were added and the new u joints installed I rides waaaaaaay better. I can still barely feel it which makes me think I need to do some fine tuning with the shimming now that the shaft is balanced. We will see..
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #6 of 6 Old 07-28-2013, 05:46 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Yah ive messed with my shimming and crap. it made it ok, but now mine has all of sudden gotten extremely worse between 65 and 75.
I haven't got under the truck yet and taken a peek....Id just assume go to a driveline shop and get a one piece driveshaft made maybe....don't know of any place around Kansas city that does it
