Which Exhaust System to go With - Ford Powerstroke Diesel Forum
Old 01-28-2008, 09:19 AM
Hey guys - I have the KEM and delete pipe at home right now just waiting to be put on. I was wondering if you can go with a 03 - 07 dual kit for the 08's or does it have to be an 08 kit. I am leaning towards MBRP but Magnaflow also sounds good. What do you guys think would be the best system for this???
Old 01-28-2008, 09:43 AM
Let's Run'em
It has to be an 08 kit for it to fit on the DPF outlet or in your case the KEM delete pipe....and of course the hangers are different I believe....Magnaflow has duals but they both come out on the same side whereas MBRP exits on each side....if you going duals I would do MBRP
Old 01-28-2008, 09:57 AM
Thanks for the quick response Julian - thats what I figured but I am getting different answers from different exhaust shops. Thought I would ask people who actually know something about this truck. I am going with the MBRP duals. I am not sure I like the dual system magnaflow have - looks too much like stock.
Old 01-28-2008, 01:05 PM
Plus it's alot more than the mbrp. Post some pics after you get the duals. I'm thinking about getting the same ones. I was going to go custom exhaust but figured its cheaper and easier to go with these.
Old 02-09-2008, 06:41 AM
Question about your HID conversion!
Our truks use the H13 low/high beem bulb. with your HID's installed do you still have the high beem function?
Old 02-09-2008, 03:51 PM
I think that I'm going to go with RBP (Rolling Big Power) exhaoust. If you leave the dpf on the exhaust gets so hot that it turns color so they actually coat the pipe black and have some great tips for the trucks as well.
Old 02-10-2008, 12:59 PM
I just installed my hids 8000k I have high beam but its not a xeon light its a bright white had to wire it in seapret from the hid harness
