Making a 6.4 800-1000hp capable cost - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-27-2013, 10:53 PM Thread Starter
mitchellfried's Avatar
Well recently I built my 5.9 to this range and I'm wondering if it would be a similar cost with a ZF6. I'd also like to know if the reliability would be the same.
I don't want to create a biggest **** contest, I'd just like to get some honest opinions. I expect it to be a little biased but I am a ford fan at heart
I'd have a 6.4 if they weren't 6-10 grand more for the same thing. Can't compare interiors or paint but you get the gist
Sent from AutoGuide.com App
1994 PSD Regular Cab Long Box
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
2006 Dodge 3500 6 Speed
846hp, 1456tq
mitchellfried is offline
post #2 of 14 Old 03-28-2013, 06:01 AM
WoodBoy's Avatar
It depends on what way you want to make it. There are many options. Single non vgt, Sequential Compound, trips, and even quads just for air
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 14 Old 03-28-2013, 08:12 AM
08stroker250's Avatar
Big air and big fuel, no problem. It's just money.
In all seriousness, are you looking for a streetable 800-1000?
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 14 Old 03-28-2013, 10:19 AM
upd103's Avatar
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
You talking HP or TQ? I'm just making sure because you said you built your 5.9 to "that level" but your sig shows 462HP and 852 TQ for the goat.
Just trying to get clarification. Maybe you had a different pulling goat, but that would lead back into 08stroker250's question. Streetable, or something else?
-David-
upd103 is offline
post #5 of 14 Old 03-28-2013, 11:13 AM
The title says "800-1000hp"
Jeff Dodd
post #6 of 14 Old 03-28-2013, 01:49 PM
fordborn's Avatar
hey buddy! i recognize that cummins ahahahaha well. custom tuning, big single kit from Maryland diesel performance, a clutch, new 85% over K16, decent sized injectors(not cheap for 6.4) and some other stupid bull****. not cheap, not terribly expensive. message me on facebook ive been looking at this for my truck. im josh sargent in case you didnt figure it out by the truck....
fordborn is offline
post #7 of 14 Old 03-28-2013, 04:11 PM Thread Starter
I would be looking for a 800hp on the street and then use the 1000 for the dyno. How expensive are 6.4 injectors. I just put some fairly expensive ones in my 5.9
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
post #8 of 14 Old 03-28-2013, 04:58 PM
Nozzles aren't bad (no need to replace the entire injector). Where it gets iffy is the turbo setup and dual fuelers you'll need. Honestly, I would go for a custom set of compounds from Maryland Performance Diesel or one of Elite Diesel's compound setups if you're looking to have a streetable 800 horsepower setup. You can make big power with a single, but you would be looking at driving around in a smokey pig at 800 horsepower....especially with a ZF6.
Jeff Dodd
post #9 of 14 Old 03-28-2013, 08:20 PM Thread Starter
Yeah I definitely wouldn't try to pull 800hp on a single and daily drive. One reason I went with twins on my truck. I've heard that the 6.4 bottom ends are good till 1000hp. Is that true?
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
post #10 of 14 Old 03-28-2013, 08:23 PM Thread Starter
I haven't updated that for awhile. Monday I put up 544hp at 1109tq on stock injectors, stock injection pump, just EFI live, lift pump and 63/68/12. Today I put down 813hp with lots of room to grow but 6.4s always seem to be calling my name.
Making a 6.4 800-1000hp capable cost-imageuploadedbyautoguide1364531034.388683.jpg
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
