DPF-R Product review - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-25-2013, 07:12 PM Thread Starter
6.4L-NREMT-P's Avatar
Thumbs up DPF-R Product review
Ok guys I have installed a DPF/Cat 4'' pipe from MBRP, S&B Stage 2 Cold Air Intake and a DPF-R plus 70HP Economy tune on my 2010' CC F250 w/ 6.4L. The Entire cost of the project including an EGR delete kit and new intake elbow that isn't installed is around 1200.00 bucks. The difference in my truck today VS yesterday is un-freakin believable!!! The power given from the 70 HP tune far exceeds what I was expecting. The DPF delete pipe I used has the bungs on it for the sensors to go back in the pipe as with this program tune it requires the sensors to be connected but not in the pipe, so , I figured why not put them back in the pipe. I have no error codes and haven't noticed any issues with the truck so far. I do like the fact that the programmer was super easy to install and also is equipped with a code reader and emergency restore feature.This "programmer" cost 445. with the 70 hp tune, you can buy the dpf delete with out the tune for about 250. It also clear's codes for EGR delete which it is recommended that you do the EGR delete with the Tuner built in one. So in the end If you are looking for a decent amount of power and don't want to spend several thousand dollars I believe this to be the way to go. I hope this helps some of you guys that are on the fence about Modifying your trucks because of money issues.
2010 F250 6.4L Powerstroke 4x4 King Ranch
S&B Stage 2 CAI
MBRP 4'' DPF/CAT delete pipe w/Bungs
DPF-R plus 70HP tune
EGR Deleted
Custom Intake Elbow
Sinister Coolant Filter
Mishimoto Aluminum Radiator
6.4L-NREMT-P is offline
post #2 of 19 Old 03-25-2013, 07:51 PM
06superduty3997's Avatar
I just got my DPF-R in today, waiting on my CAT/DPF delete pipe to get in thanks for the review man.
2008 F-350 FX4 CCLB 6.4 Powerstroke
SCT Livewire With RCD Tunes. Magnaflow 5" Straight Pipe Exhaust with an 6 inch tip
Airaid drop in filter with a modded stock box. Halo/LED headlights, LED Mirror, Dually Fender Lights.
2.5 leveling kit Soon to Come,
Road Armor Front Bumper with Pre Runner Bar.
AF 19.5 wheels black
LED D2s and light bar
06superduty3997 is offline
post #3 of 19 Old 03-25-2013, 07:57 PM Thread Starter
did u get the one with the 70hp tune? if not it is deffinatly worth the extra money, however, they say if u install that one first u can use a live programmer on top of it, not sure though, hope u like it as much as i do!!!
S&B Stage 2 CAI
EGR Deleted
Custom Intake Elbow
post #4 of 19 Old 03-25-2013, 07:58 PM Thread Starter
Beautiful truck BTW !!!
S&B Stage 2 CAI
EGR Deleted
Custom Intake Elbow
post #5 of 19 Old 03-25-2013, 09:22 PM
NREMT,
Thanks for the review. Once you run the tuner for awhile, let us know what mileage gains you're seeing if any.
Thanks again.
mangymarmot is offline
post #6 of 19 Old 03-25-2013, 09:27 PM Thread Starter
No problem I surely plan to start checking my mileage manually on my next fill up.
S&B Stage 2 CAI
EGR Deleted
Custom Intake Elbow
post #7 of 19 Old 03-26-2013, 05:56 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Would you post links of where you got your stuff? I've been trying to research the DPF-R stuff as there have been lots of questions on it recently. I believe it might be the best option for guys who want to stay at or near stock power levels, but once you decide to stack tuners to get the +200-300HP tunes, cost is getting mighty close to he stand alone Spartans or SCTs with custom gearhead or innovative tunes.
I know my roommate (albeit he had a 6.7 cummins) is trying to find an option similar to yours (doesn't need or want the extra power), but doesn't want to spend the cash on a H&S.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #8 of 19 Old 03-26-2013, 09:10 AM
I got the standard one without the 70HP tune, and thanks man I was looking at getting an KR F-250 before I decided on the one I have now.
post #9 of 19 Old 03-26-2013, 09:52 AM
soundmandave21's Avatar
I have the DPF-R with the 70 horse tune. I gotta say, I am not overwhelmed by it. I notice the extra power in 5th gear, but nowhere else unless I absolutely mash the throttle. Dunno if there is something wrong with my rig or what... If this thing had the power in 1st -4th that it has in 5th I would be ecstatic. I also only gained about 1 mpg, if that.
1997 4x4 F-250 Xcab LB, ChildSeat
soundmandave21 is offline
post #10 of 19 Old 03-26-2013, 03:58 PM Thread Starter
wow soundmandave did u do air filter upgrade? idk if that makes a big difference but in my truck the dpf-r programmer really made a huge difference in my truck, alot faster throttle response, and turbo is making much more boost. I havnt run a larger tune so I dont really have much to compare by but for me it was difference as night and day.
Aggie I purchased all of my stuff from XDP. Xtreme Diesel Performance - XDP Diesel Power Performance Parts great customer service and was fast to answer any questions also if you use diesel10 at check out save 10 percent on most items.
S&B Stage 2 CAI
EGR Deleted
Custom Intake Elbow
