Whats Your EGTs at WOT - Ford Powerstroke Diesel Forum
post #1 of 45 Old 03-24-2013, 03:21 PM Thread Starter
What is the highest EGT these trucks should see. Under a quick WOT run I hit 1800 degrees. Spartan 300 tune, sinster EGR, MBRP turbo back 5".
Trouble maker is offline
post #2 of 45 Old 03-24-2013, 04:50 PM
WoodBoy's Avatar
Thats pretty hot, Try not to see more than 1500 for sustained time I thought the factory sensor maxxed at 1760* Anyways You need to invest in a cold air intake since you didnt list that. That is your main problem. The 300 tune is more DD tune and not a race tune and runs a little warmer than the 275 and 310
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 45 Old 03-24-2013, 05:16 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I never break 1350 on my truck...
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 45 Old 03-24-2013, 06:13 PM
WoodBoy's Avatar
Regen mode on a completely stock truck has extended periods (minutes?) of 1100-1300. Some trucks see close to 2k* on the track but thats only for a few sec
WoodBoy is offline
post #5 of 45 Old 03-24-2013, 06:53 PM Thread Starter
I've only done short run 20 seconds or so and my spartan will give me a high read out
post #6 of 45 Old 03-24-2013, 07:02 PM
BIG Laing's Avatar
That's is down by the DPF that is designed for those temps. The turbo is what we are worried about when EGT's are above 1400.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #7 of 45 Old 03-24-2013, 07:03 PM
BIG Laing's Avatar
You are smart.
post #8 of 45 Old 03-24-2013, 09:01 PM
Originally Posted by BIG Laing View Post
You are smart.
I try to choose my mods to maximize efficiency and reliability. I run the 300 tune, but with all my air in/out mods, heat doesn't seem to be an issue. I set my alarm at 1350 and I don't remember the last time it went off. Probably pre AFE intercooler.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
post #9 of 45 Old 03-24-2013, 10:41 PM
srjd's Avatar
Quoted: 2 Post(s)
My alarm is also at 1350 and its almost impossible for me to hot that. Cold air intake brought my temps down huge. 1800 is scary hi
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #10 of 45 Old 03-25-2013, 12:31 AM
08stroker250's Avatar
Wrong. Pre-turbo EGT's will sustain 1100-1300 degrees during regeneration on a 6.4L.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
