Down pipe and dpf delete - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-23-2013, 10:30 AM Thread Starter
Whbhauling's Avatar
After ready a couple posts about the down pipe restriction I decided to replace it. Also I had previously purchased a mini max and cat/dpf delete pipe from PTP( cheap shameless plug). I installed the mini and liked the results but not the delete pipe. I was worried about the smog laws as the registration is due in June. Well living in the state of California is a pain. I decided to research the law and found out that my truck does not require inspection. The reason is the GVWR of my truck is 14500 the break is 14000 and under. So I jumped right in. first thing I did was wrap the down pipe with DEI Titanium exhaust wrap ( 1"x50"). First I washed the MBRP stainless pipe bought from PTP ( cheap shameless plug) with soap and water to remove any oil. then using a 4 inch stainless hose clamp I made one wrap on the pipe and installed the clamp. Positioning it so not to interfere with any components. Then I wrapped the pipe per instructions and finished just above the area where the to halves of the pipe slip together and placed the second clamp. Positioning it so not to interfere with any components. Then I used stainless safety wire and wrapped the outside to help maintain the integrity of the wrap during and after the install. In the future I may wrap the lower section also. Over all I am happy with every thing the items to install are egr block off and S&B air filter or cai
ID:	86370   Click image for larger version
ID:	86378   Click image for larger version
ID:	86386   Click image for larger version
Whbhauling is offline
post #2 of 4 Old 03-23-2013, 10:53 AM
Nice job.
How is the fit of the pipe overall?
How much clearance is there with the cab, frame and bellhousing?
tensixniner is offline
post #3 of 4 Old 03-23-2013, 12:07 PM Thread Starter
Whbhauling's Avatar
Fit is good Once i got the upper pipe in then the lower I installed the delete pipe in the hangers then snugged up the clamps then barred the pipes around to get clearances and tightened them all up. I will post pics tonight when i get home from work
ID:	86570   Click image for larger version
ID:	86578   Click image for larger version
ID:	86586   Click image for larger version
post #4 of 4 Old 03-23-2013, 07:36 PM
44magnum's Avatar
Quoted: 2 Post(s)
That's is the exact same DP and wrap I have, I also got my setup from PTP! I think you'll like it, I saw a good 100-150 egt drop with it.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
