Spartan 300 tune - Ford Powerstroke Diesel Forum
post #1 of 48 Old 03-22-2013, 02:52 PM Thread Starter
joesuprdty's Avatar
Unhappy Spartan 300 tune
I was wondering why the Spartan program 300hp is not smooth when the truck shifts into a higher geer I have not tried the 275 and it does the same thing i love the power and the sound but what can i do to clear up the jerky throttle I am installing ladder bars soon but i dont think this will cure is it the TUNE ? please help any suggestion would be great
F 350 6.4 12 " custom lift 40 X 15.5 X 20 Toyo tires 20 x 14 fuel full blown two piece wheels Home made ladder bars
Spartan tuner Sinister EGR full delete Custom air intake Flo Pro 4'' dual pipes tripple pod gauge set up
joesuprdty is offline
post #2 of 48 Old 03-22-2013, 03:01 PM
08stroker250's Avatar
Are you experiencing a bucking sensation once the converter is locked? If so, traction bars will greatly reduce this. It's related to the touchier throttle the larger tunes have. Axle wrap enhances the jerkiness.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 48 Old 03-22-2013, 03:02 PM
DirtyDiesel's Avatar
Quoted: 3 Post(s)
ive found with mine the higher the tune the more "touchy" the throttle is. with the 350 tune being completely unusable for everyday driving. shifts will smooth out with driving if you stay out of the throttle. im on the 310 tune and like it, PLENTY of power, good fuel mileage (better than 275), and a good trade-off on throttle touchy-ness from the 350.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #4 of 48 Old 03-22-2013, 03:04 PM
Quoted: 3 Post(s)
mine actually has a "shutter" to it and i can feel the rear end wrapping and actually bouncing from the wrap. traction bars are in my future for sure.
Brett
post #5 of 48 Old 03-22-2013, 07:47 PM Thread Starter
joesuprdty's Avatar
I will keep up with this until a cure is found when you feather the throtle its not bad but when you hit the pedal at a certain rpm or a certain gear change it goes buck wild it could be due to od kicking in or the torque converter like stroker stated i am running the 300 tune i would run a 500 tune if i could more power is in the future i am addicted to diesal power
post #6 of 48 Old 03-22-2013, 09:00 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Spartan 300 tune
I don't understand these posts. I run the 300 and my shifts are silky smooth! Literally just turned to my buddy and asked how he would describe the drivability of my truck. His words, "drives like a stock truck, I don't feel your shifts unless you are flooring it, and then I really only feel quick shifts and the torque converter locking."
I do also have traction bars which make a world of difference, but I don't remember the shifts being bad before the bars.
Maybe I'm just lucky and got a gem of a truck....
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #7 of 48 Old 03-22-2013, 09:05 PM
Quoted: 3 Post(s)
mine arent bad UNLESS i give it excessive throttle. soon as i get to what i would call a fast acceleration the shifts get hard. but driving normal and staying with traffic truck drives stock, all-be-it more aggressive throttle.
Brett
post #8 of 48 Old 03-22-2013, 10:20 PM
Gotta keep those stock clutches from slipping.
Jeff Dodd
post #9 of 48 Old 03-22-2013, 10:44 PM
F250Marine's Avatar
I run the 300 EL as my DD, and have had no issues. Shifted a bit hard when i first loaded it, but now shifts great. As of now no traction bars.
One issue i have had is after running the tunes for a few thousand miles, when i let off the throttle and coast to a stop and traffic takes off and i get back on the throttle i get really bad transmission flare. it almost seems like it goes into neutral. then when i get back up to about 45 mph where the tc should lock up it doesnt for a few. Anyone know what is up with this?
F250Marine is offline
post #10 of 48 Old 03-23-2013, 05:33 AM
Quoted: 3 Post(s)
X2. I also have this issue sometimes. Like whenever someone in front of you slows down to turn then turns off and you get back in the throttle the motor revs up for a second then catches.
Brett
