Mini maxx ebp readings - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-19-2013, 10:39 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
How does the mini read ebp? Does it incorporate baro into it? What should my reading be at idle
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 4 Old 03-19-2013, 11:19 PM
Capt dong's Avatar
Quoted: 5 Post(s)
It reads true. The EBP ratio can be as high as 3:1 in single digit boost. At idle I think the EBP is 2 psi or lower. It's been a while since it's been on my gauge set. Hope that helps.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 4 Old 03-19-2013, 11:29 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Mine was flashing back and forth to 3 and 4 at idle. My baro is always 12 which is weird cause that's not the actual pressure where I'm at. Is 3-4 bp to high at idle? What should it be when cruising?
srjd is offline
post #4 of 4 Old 03-20-2013, 06:05 AM
WoodBoy's Avatar
It varies depending on how the tune is setup. You dont want to see higher than 70 at WOT on a minimax since it doesnt add barometric
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
