B&M Hi-Tek Trans cooler - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-19-2013, 05:38 PM Thread Starter
colfaxent's Avatar
Is anybody running a B&M or whatever brand aux trans cooler with a fan? If so wher did you mount it and how did you mount it. How well does it work? Thanks. JIM
2009 F350 Crew Cab
H&S Black Maxx Tuner
S&B Intake
2010 Cameo 36FWS 5TH Wheel
Hellwig Sway Bar
MBRP Cold Side Pipe
Closed system CCV mod
5160 Bilstiens x4
Icon 2.5 Front springs
PMF Floating Traction blocks and bars.
PMF Dual Steering Stabilizer
colfaxent is offline
post #2 of 11 Old 03-28-2013, 08:38 PM
early99psd's Avatar
Quoted: 13 Post(s)
i have the hi-tek cooler with fan on a E99 and it still does not cool that great. The fan is set to turn on at 175 but when it kicks on it reads 190 on my gauge. I don't know if the gauge is reading different temps because its in the side of the trans. I have not been happy with the cooler. I just picked up a 6.0 cooler and am going to change. Plus the cost of the hi-tek cooler and all the wiring was way more. Wished I had just done the 6.0 cooler first.
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #3 of 11 Old 03-29-2013, 04:05 PM Thread Starter
colfaxent's Avatar
Is the 6.0 cooler bigger than the 6.4? I know it is bigger than the older and gas models , not sure,
2009 F350 Crew Cab
S&B Intake
Hellwig Sway Bar
MBRP Cold Side Pipe
5160 Bilstiens x4
post #4 of 11 Old 03-29-2013, 04:07 PM Thread Starter
colfaxent's Avatar
Were did you mount it? Is it getting enough air?
2009 F350 Crew Cab
S&B Intake
Hellwig Sway Bar
MBRP Cold Side Pipe
5160 Bilstiens x4
post #5 of 11 Old 03-29-2013, 08:38 PM
early99psd's Avatar
Quoted: 13 Post(s)
It is right behind the front license plate
Sent from AutoGuide.com App
post #6 of 11 Old 03-31-2013, 07:01 AM
Quoted: 2 Post(s)
Are you experiencing overheating? I have never seen my trans gauge move past the spot it gets after getting up to operating temp. I have 37's and have towed some pretty good weight in some pretty hilly terrain with the Spartan 275 tune and like I said before the gauge stays in the dead middle like it always does. Is this gauge one of those "dummy" gauges? I did switch the ATF to Amsoil so that might help a little.
713Diesel is offline
post #7 of 11 Old 03-31-2013, 01:52 PM
Quoted: 2 Post(s)
check this thread out.
HEAVY DUTY TRANS COOLER INSTALL
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #8 of 11 Old 03-31-2013, 04:33 PM Thread Starter
colfaxent's Avatar
I pull a 14k 5th wheel and live in upstate new york, so long steep hills in the Adirondacks and Green moutains of vermont tend to make trans temp skyrocket once the converter unlocks at slower speeds. The factory trans temp gauge doesnt move until about 220F. And the fan doesnt kick in until about that temp also. For a short time I have seen 240 when climbing up in to Lake Placid. I plan on mounting the cooler under the truck , possibly between the rt side rocker and frame or under the bed. Also wiring the fan to the upfitter switches for intermittent on demand operation. Let me know if anyone has any mounting ideas or pics of installs. JIM
2009 F350 Crew Cab
S&B Intake
Hellwig Sway Bar
MBRP Cold Side Pipe
5160 Bilstiens x4
post #9 of 11 Old 03-31-2013, 07:04 PM
Quoted: 2 Post(s)
check the link i put in this thread before this post.. has a good "how to" install for what your asking.
Kris
post #10 of 11 Old 04-01-2013, 06:12 PM
Quoted: 2 Post(s)
If the additional cooler doesn't help you out you might want to look into one of the early lock tunes.
