Cold air intake ? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-19-2013, 06:06 PM Thread Starter
Question Cold air intake ?
I have a 08 F250. I bought it used and it came with a K&N intake. I have been considering putting a AFE or S&B on it. My local dealer is telling me that I need to return to the stock ford setup. He says the K&N is letting dirt into my engine. It is very dusty where I live. Any ideas? The dealer also told me that if I did not turn my H&S tuner down to the "no power" level, I would destroy the exhaust manifold gasket. Opinions please
2008 F250 XLT Supercab 6.4L
rksorrells is offline
post #2 of 12 Old 03-19-2013, 06:37 PM
Evil PSD's Avatar
From what I have read, K&N filters are awful esp being in a dusty climate, they let more dirt in then air. I'd use either oem filter or AFE PG7 filter. As for the exhaust manifold gaskets thats a first I've heard of that, you sure he didn't say head gaskets? Head gaskets will eventually go south on higher tunes unless you stud the motor.
2010 F250
H&S, 5" Flo pro, PMF 2" coil spacers w/ plow coils, radius drop brackets, 4.5" blocks, adj track bar, Bilstein 5100, ATX Ledge 18x9 wrapped in 325/65/18 Duratracs
Evil PSD is offline
post #3 of 12 Old 03-19-2013, 07:00 PM Thread Starter
They definitely said exhaust manifold gasket, no mention of the head gasket. I'm running the "mild" selection on the tuner. Just trying to get better mpg. If I go back to stock with the air intake, won't I lose power and mpg?
post #4 of 12 Old 03-19-2013, 07:07 PM
Evil PSD's Avatar
Generally the higher tunes you get better fuel mileage, but as for air filter i believe the stock is good for 500hp. Would you rather have a filter that filters good or better performance? The PG7 filters the best out of the 3 from afe.
2010 F250
Evil PSD is offline
post #5 of 12 Old 03-19-2013, 08:01 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Cold air intake ?
Get either an S&B or an AFE if you want to run high tunes, otherwise stay stock filter. As far as damage, you have to pay to play, but as long as you are sensible you won't break anything.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #6 of 12 Old 03-19-2013, 09:09 PM Thread Starter
The performance from the factory is fine with me. I bought a diesel for the longevity. I want the best protection for my truck that I can afford. Better fuel mileage is a close second. I bought the H&S tuner and did the dpf/doc delete because of reading the problems the regeneration cycle was causing the engines. I thought the factory air filter did not do a good job of protecting the engine. Have I been misled?
post #7 of 12 Old 03-21-2013, 09:12 PM
Has anyone ever seen a cold air intake system with a fender scoop?Kinda looks like a hood scoop except on the fender.
slingwing is offline
post #8 of 12 Old 03-21-2013, 10:07 PM
Mexigeo's Avatar
Cold air intake ?
Like this - http://www.rudysdiesel.com/_e/Air_In...oop_Intake.htm
2009 F350 SC FX4 6.4 Powerstroke
Originally Posted by Big Angry Hillbilly View Post
I hear that Dodge gives you a puppy with every truck you buy, so you'll never have to walk home alone again.
Mexigeo is offline
post #9 of 12 Old 03-22-2013, 05:20 AM
Yup, that is the BD set-up....I'm running their scoop with my S&B set-up....I moddified the air dam in my fender to make this work (I did not use theirs)....I posted some pictures and instructions about a year ago. Bottom line is, the power stayed the same, but my EGT's dropped a legit 30+ degrees when I hammer on it.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #10 of 12 Old 03-22-2013, 05:58 AM
Cold air intake ?
Originally Posted by Mexigeo View Post
That's just ridiculous. I'm sure it works, but seriously? I think that would look just terrible on the side if the truck. Plus it looks like it disconnects the scoop behind your headlight.
-Tyler
Texas A&M c/o 2010
