Airdog2? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-19-2013, 11:01 AM Thread Starter
dogrider's Avatar
Airdog2?
I wanted to get info on a air dog II . I have an 08 with h&s mini max and delete dpf and s&b intake. Does anyone have a air dog on there's. Does it make a big difference and how hard is install. Thanks for help. Chris
dogrider is offline
post #2 of 13 Old 03-19-2013, 11:34 AM
WoodBoy's Avatar
The difference it makes is changing fuel filters and keeping the hpfp a little more happy but as far as power difference there wont be one. I think it even filters better than factory specs.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 13 Old 03-20-2013, 09:35 PM
miles97's Avatar
Better filtration is the biggest reason to install an aftermarket system. Just going to say that 3 out of the last 5 Air Dog systems that I have installed have lost the motor in the pump within 10,000 miles.
I will be installing FASS inless the customer would rather the Air Dog.
Just my 02 cents
97' F250 7.3 XCSB Standard 203,500 miles
T&S 6 position, Sraight piped, K&N
SOLD
05' F350 6.0 CCSB Auto 155,000 miles
Edge Platnium W/hot, 4" Sidepipes, AFE intake, leveling lift 325/65R18
00' Camaro SS 6-speed standardT-tops 73,000 miles
SLP Airbox SLP loudmouth exhuast custom tuned
73' F100 SCLB Standard ? miles
Built 390, lockers, 7" lift, 35 12.50R15
miles97 is offline
post #4 of 13 Old 03-21-2013, 03:57 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Airdog2?
I have an airdog, works great now. Biggest reason as stated above is filtration followed closely by more fuel pressure to the rest of the system (ie your engine doesn't starve for fuel).
Btw miles, when your pumps failed what happened? Just failed to start or something more catastrophic?
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #5 of 13 Old 03-21-2013, 04:14 AM
Subscribed....I would like to know too. I was going to order my Air Dog today. I ran a FASS on my Dodge and loved it....However, eveyone seems to like the AD on the 6.4?
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #6 of 13 Old 03-21-2013, 04:21 AM
08stroker250's Avatar
Most people prefer the Air Dog over the FASS because of size and noise. The filters are much smaller and pump is much quieter with the Air Dog.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #7 of 13 Old 03-22-2013, 02:54 AM
drservo's Avatar
Are there any benefits to replacing the LPFP with an Airdog?
08 F250 CC, 4x4, Blue/Pueblo Gold, 3.73, S & B CAI, 5" Magnaflo downpipe back, Spartan TCM 275 & 310 KEM 345 (SCT - Sold) Mickey Thompson 35 12.5 20's
drservo is offline
post #8 of 13 Old 03-22-2013, 06:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The failures are on high pressure systems. On the 6.4 the airdog is a low pressure system and i have not heard of any problems on the 6.4. The 6.0 guys are the ones having problems with the airdogs.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #9 of 13 Old 03-27-2013, 08:49 AM
miles97's Avatar
One was on a 6.4 and the other two have been on Duramax. On all of them the motor that drives the pump goes bad and blows the fuse. Replace the motor and it work fine.(for awhile)
SOLD
miles97 is offline
post #10 of 13 Old 03-27-2013, 08:52 AM
Term3's Avatar
Quoted: 2 Post(s)
Hot running motor is ONE issue. Shaft seal is another issue.
Term3 is offline
