Front airbags? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-12-2013, 11:14 AM Thread Starter
rocknmj's Avatar
Front airbags?
So I'm getting ready to order rear bags and a compressor and I'm just wondering if anyone has any thoughts about whether putting the internal coil spring bags on is worth the money. About another $200 for the bags and the dual output guage.
I'm just wondering if it would be worth it.
Sent from AutoGuide.com App
2008 Lariat 4x4 CCLB DRW
H&S Mini, S&B Intake
AirDog 2, Beans Diesel Sump
DieselSite Coolant Filter, CAC Boots, Tranny Filter
rocknmj is offline
post #2 of 19 Old 03-12-2013, 11:16 AM
fordpwrstroke7's Avatar
Not worth it. I have rear bags and they're perfect for hauling. Fronts are a gimmick.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 19 Old 03-12-2013, 05:56 PM
44magnum's Avatar
Quoted: 2 Post(s)
I don't know what you could possibly need front airbags for. My front springs are PLENTY stout, but I do have the snow plow package.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #4 of 19 Old 03-12-2013, 06:22 PM Thread Starter
rocknmj's Avatar
Re: Front airbags?
That's what I figured, but thought I should get some other opinions so if I needed a dual control compressor I could get it now. I ordered just the rear ones today with a Firestone compressor. Anxious for it to get here.
rocknmj is offline
post #5 of 19 Old 03-13-2013, 06:40 AM
bigt2317's Avatar
I know you already ordered them but I agree that the front are a waste UNLESS you get a true airbag only set up in front and a true airbag only set up in the rear. Doing this would make the ride way better but then you'd have to worry about leaks and not to mention the cost of this.
I put some firestone helper bags on the back and got a airlift wireless compressor on mine
Travis
2008 F350 King Ranch - A few fun things, Newton 2-1/2" leveling kit, HID headlights and fogs, 325/60 Hankook Dynapro ATM2's on stock 20" wheels, Firestone ride rite air bags, Air Lift wireless air controller, B&W gooseneck, Diesel site coolant filter, 30" LED bar
2005 Jeep Unlimited Rubicon - with some stuff
bigt2317 is offline
post #6 of 19 Old 03-13-2013, 07:10 AM Thread Starter
rocknmj's Avatar
Re: Front airbags?
I didn't get the front ones. After everyone's input and talking to the guy at SD Truck Springs, I figured they weren't worth it. I just went with the rears and on board air. Thanks for the opinions guys.
rocknmj is offline
post #7 of 19 Old 03-13-2013, 10:05 AM
bigt2317's Avatar
Gotcha, what I meant was I knew you already ordered your setup without the front's. I'd love to find someone that has actually done a full front and rear bag setup to hear their review. While I do love my rear helper bags, they make my one ton ride even more like a tank. No so fun for a daily driver and I'm thinking of maybe pulling a leaf or 2 out of the stock spring pack to soften the rate up a little.
Travis
bigt2317 is offline
post #8 of 19 Old 03-13-2013, 12:11 PM
Your truck shouldn't ride any differently with the rear airbags if you're unloaded. You're only supposed to put 5psi (can really put more than that though) in them unloaded so it doesn't affect your ride quality. With a load and the airbags aired up, your truck rides much better.
2008 F-350 CCLB
post #9 of 19 Old 03-14-2013, 06:14 AM
bigt2317's Avatar
Empty at 5psi the rear of my truck raised up just over 1/2" from stock so it did make mine stiffer, especially when I hit bumps at speed because now that 5psi is compressed to 10psi due to the suspension cycling.
I will say that you are correct with the loaded ride. It does ride a TON better when loaded down and my bags aired up, even 1000 in the bed makes a difference.
Travis
bigt2317 is offline
post #10 of 19 Old 03-27-2013, 03:42 PM Thread Starter
rocknmj's Avatar
Just got my bags finished up. I have a compressor, but I'll have to wait to put that in until I have more time. Time for a test drive now!
ID:	88658   Click image for larger version
ID:	88666   Click image for larger version
rocknmj is offline
