Help need help - Ford Powerstroke Diesel Forum
Old 03-08-2013, 08:23 PM
Help need help
I have a question I put a tune in my 6.4 yesterday road on it like for about 2 hours or so everything was good today the same thing till later on at night it said cleaning out exhaust filter is it suppose to do that it rev by it self when it's in park and it also blow out some white smoke
Old 03-08-2013, 09:45 PM
Couch warmer
If you're running a "dpf installed" tune, yes it will clean the exhaust filter, high idle is normal as well as a little smoke. If it's removed and then you need a dpf delete tuner.
Is your dpf removed or installed?
Help need help
I know you are freakin out a little, but no need to post in every section. One is enough and you will get a timely answer.
Sent from AutoGuide.com App
