H&S temp numbers
I have a mini max running the HD tunes on wild and was wondering what you were seeing as your temps in the areas on coolant, oil, and trans temp. My coolant is around 195 pretty much all the time when it gets to normal running temperatures and the trans temp is around 165 to 170. I dont run the truck hard at all except for a few seconds every now and then. My concern is that these temps are high. What are yall seeing in these areas?
Those temps are good. My coolant usually floats around 195 to 199 depending on getting off of highway and hills etc. Trans usually the same as yours unless loaded with a trailer. Your oil temp should be a few degrees above coolant also
