DPF delete pipe - Ford Powerstroke Diesel Forum
Old 03-03-2013, 03:00 PM
DPF delete pipe
Has anyone ever made a dpf delete pipe. Im a sheet metal shop foreman and have all the resources to do so exept put a bend in 4" pipe. Is the pipe straight or does it have a slight bend in it? Also if im running a SCT 3015R do i need bungs?thanks guys
Old 03-03-2013, 04:16 PM
Feedback Score: 7 reviews
It's got a a bend in it and a ball and socket flange. Easier just to buy the delete pipe and even better just to buy a down pipe back kit.
Old 03-03-2013, 05:04 PM
DPF delete pipe
I wish I could buy a down pipe but I live in CA. And I need to leave the flanged connection for smog purposes. With the sct 3015R do I need bungs?
Sent from AutoGuide.com App
Old 03-03-2013, 05:41 PM
Down pipe back leaves the flange. Then all you do is put the dpf back on and th tail pipe. That's the way I have mine. I have stock down pipe which has the flange connection at the bottom. Then to 5" down pipe back. It takes me about an hour and a half to take the 5" off, hang the dpf and bolt in the tail section. Sct requires the sensors to be plugged in but they don't have to be in the exhaust pipe. If you don't plug the sensors in, it will idle really high
Old 03-03-2013, 06:02 PM
DPF delete pipe
That's something I'll do in the bear future. I Already had to try to swing a tuner by her after I dropped $3000 on a new mountain bike last month. For now I just want a dpf cat delete pipe in there. Then later I'll do a down pipe. Thanks for your help.
Old 03-04-2013, 06:31 AM
What he is trying to tell you is the bottom of the downpipe (stock and aftermarket) is a ball type end. The end that connects to it is a socket style end that is on the fron of the dpf/cat that you want to remove, therefore, the dpf/cat delete pipe needs the socket style end
Old 03-04-2013, 06:52 AM
DPF delete pipe
Ohh. Thanks for clearing that up. My truck is being serviced right now. So I have not been able to get underneath it yet to look
Old 03-04-2013, 07:41 AM
You can see it in this pic (downpipe) the shorter section has the ball type end 4
While in this pic (the dpf/doc delete) has the socket style end. AFE Mach Force XP DPF Delete 4" Race Pipe Kit (with Bungs) 49-43024
the flange piece that is on each one has two bolts that run through it to keep the ball and socket tight to each other
Old 03-04-2013, 10:57 AM
DPF delete pipe
Who has the best deal right now on a dpf/doc pipe right now
Old 03-04-2013, 11:47 AM
Just call PTP or Rudys diesel. Ordering online isnt for the person looking for deals
