Spartan EGR delete?
With the spartan tuner can I shut off then EGR without having to install anything and just do it from the tuner?
The 275 and up tunes all turn off the egr. the 210-250 only cycle the egr at idle. you can down load the egr delete tunes from Spartans website
This guy is right. If you do a full delete you can either run the 275 and up tunes all the time, or you can take a few min. to download the full egr delete tunes (NEGR) from Spartan's website and run any of the tunes you want
Run any of the tunes with the EGR Delete?
We have 40 HP - 250 HP EGR delete files available for download on our website once you have logged in.
What are the pros and cons of the EGR Delete?
basically running exhaust back into your intake for the engine the rebreath its own exhaust or shutting the EGR valve so it mostly breaths only its clean fresh air
An egr delete is all pros, no cons.
So I don't need to buy an EGR delete the tuner will just do it
I would suggest doin the egr delete with intake elbow, as the stock one with the egr valve on it is restrictive. But if you are still under warranty or live in a nazi emmissions testing state I would not do it unless you are wanting to put it back on each time you have to take it in. As soon as I'm out of warranty I will be deleting mine, but for now I'm just running the spartan 300 with egr turned off.
