Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 12-30-2007, 03:11 PM
Dr.Palmar Dr.Palmar is offline
Engine Oil
Which oils do you guys use and what do you like? I am trying to decide what to go with in my 08. I have always been told stick with one oil for the life of the truck
Old 12-30-2007, 03:33 PM
FIRE911 FIRE911 is offline
Amsoil is one of the best oils for diesel engines.
AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases
Old 12-30-2007, 03:44 PM
WD40 WD40 is offline
Shell Rotella T 15 W 40 is hard to beat. There are probadly more diesels on the road today using Shell Oil. If it's a new truck and you want to use Synthetic Motor Oil, put about 20,000 on it and then change it over to a Synthetic Motor Oil like Amsoil.
Dr. enjoy your new truck and Welcome to the ORG.
Post some pictures of your truck and tell us where your from.
Old 12-30-2007, 03:48 PM
Rotella T is also very good oil.
Old 12-30-2007, 03:49 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
im not a big amsoil fan , but im not gonna knock any brand of oil, i run shell rotella my self and thats what i put in all my customers trucks , ill agree that there are more diesels on the road running rotella than probably any other , in my opinion , as long as the oil gets changed in your engine when its supposed to thats the main thing , oil changes and maintenance are very crucial to the life of the powerstroke engine
Old 12-30-2007, 04:36 PM
Tikal Tikal is offline
Thas how we do'r in Dixie
Send a message via AIM to Tikal
Running Delo 400 at the moment. I've heard not-so-good things about Rotella's anti-foaming agent breaking down in a PSD
Old 12-30-2007, 05:27 PM
Dirk Dirk is offline
Diesel Innovations
I've always run rotella 15w40. Works perfectly.
And I've never heard of it foaming up and causing HPOP/injector issues on a psd.
Old 12-30-2007, 05:41 PM
Just what I've heard. I'm no analyst or scientist, but I heard their anti-foam agent was JUST good enough to meet requirements for a psd and after 3k miles it starts breaking down because of the high pressure system. This is coming from someone at a local diesel shop (Southeast Diesel in Chattanooga).
*shrug* Maybe I'll just switch to Amsoil
Old 12-30-2007, 05:46 PM
Chrisf97305 Chrisf97305 is offline
Send a message via Yahoo to Chrisf97305
I am running AMSOIL 5w-30 in my 97 Powerstroke and it likes it. Smoth idle, and great starts, Even when its cold. (1 glow in -10) I am running AMSOIL bypass set up, change filters every 7,000 and change oil 1 a year (about 25,000 Miles) I use to use rotella 15w40 and would use about a qt at 3,000 miles. Now I don't see any oil lose untill about 7,000 and thats when I change my filters and top off with new oil. (about 4 qts-bypass filter 2 qts, full flow filter about 1 qt and the last qt to bring it back to the full mark.
