EGR Valve? - Ford Powerstroke Diesel Forum
Old 02-25-2013, 04:38 AM
Send a message via MSN to chihuahuaford
EGR Valve?
Do most tuner close the egr valve?
Edge
Spartan
Sct
H&S
Sent from AutoGuide.com App
Old 02-25-2013, 06:17 AM
Cant speak for edge, I know the other three do. Are you wanting to know if they turn off the egr valve with the egr in place or are you wanting to know if they allow for you to do a full EGR delete?
Old 02-25-2013, 06:19 AM
ADMIN AND TECH
im having trouble remembering if edge does or not myself but the other 3 do , when you select the egr off option, it doesnt matter if egr valve is in place or not , the software just eliminates egr either way
Old 02-25-2013, 04:42 PM
i have a SCT 3015R on a 08 6.4L. and when i set it up should i choose yes for the option if i have deleted the EGR? cz as of now its running with dpf delete performance tune performance trans with NO egr delete. iv also had engine sputtering since i installed the tune. Its okay to run EGR delete without the delete kit?
so should it be:
DPF delete
EGR delete
performance HP
Performance trans
Old 02-25-2013, 05:18 PM
Ive always recommended and even seen the guys like IDP recommend selecting "Yes, I do have an egr delete installed" even if it is still attached to the vehicle. All it does is keep the egr valve commanded shut which is a good thing. Nothing bad about it.
