High egt's - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-19-2013, 08:03 PM Thread Starter
I B STROKEN '10's Avatar
High egt's
How much will a 4" dp help my egt's? I have 5" dp back now with afe cai. I was doing the tranny learn with the h&s and hit the egt defuel (1450) running 50% throttle. My cruising temps seem to be normal but I don't think I could make it through a 1/4 mile at wot. Also would bigger tires cause more drive pressure thus causing higher egt's? Don't know, maybe that's a dumb question.
Sent from my EVO using AutoGuide.Com Free App
I B STROKEN '10 is offline
post #2 of 10 Old 02-19-2013, 08:18 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
High egt's
It will probably be around 50 degrees. That's what I saw. And yes bigger tires will cause higher EGTs because your engine is working harder.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 10 Old 02-20-2013, 07:31 AM
strokin07's Avatar
Re: High egt's
What size tires do you have and what gears? That's pretty high egt for half throttle on h&s tunes.
Sent from my SCH-I535 using AutoGuide.Com Free App
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #4 of 10 Old 02-20-2013, 07:42 AM Thread Starter
Re: High egt's
I have 37" tires with 355 gears.
post #5 of 10 Old 02-20-2013, 07:52 AM
strokin07's Avatar
Re: High egt's
Well that gear is a bit high for those tires but still shouldn't get that hot at half throttle. What is your low boost fueling set at? If it's high set it down to 0 or 1.
2008 F-250 KR
7" ICON
7" PMF blocks
22x14 Fuel Octane
37" Toyo M/T
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
post #6 of 10 Old 02-20-2013, 08:25 AM Thread Starter
Re: High egt's
It's set at default (3 I think). I will try turning it down. Thanks.
post #7 of 10 Old 02-20-2013, 09:30 AM
WoodBoy's Avatar
Sounds high for any tunes at half throttle
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 10 Old 02-20-2013, 02:04 PM
44magnum's Avatar
Quoted: 2 Post(s)
Ya that sounds high to me as well, and I have my LBF set at 5. My 4" DP droped my egts somehwer between 50-100 degrees. Cruising down the highway at 70mph I saw about an 80 degree drop.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #9 of 10 Old 02-20-2013, 06:39 PM
WoodBoy's Avatar
I would recommend your LBF on 0 or 1. Dyno has proven better numbers with it turned down if you mash on it hard
WoodBoy is offline
post #10 of 10 Old 02-20-2013, 07:20 PM Thread Starter
Re: High egt's
That seems to be the consensus. I'm going to change it this weekend and see what happens.
