Spartin!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-19-2013, 05:37 PM Thread Starter
Spartin!!
man just installed it!! It makes the dash seem so hard to touch. Anyways I'm only running the 150 DPF tune, but dang if this is only half of it I can't wait. When I plugged it in my Fuel Rail Pressure is sitting at 35000 or so, factory setting is max 30 so the buzzer was going off. Is 5000psi bad?
Trouble maker is offline
post #2 of 7 Old 02-19-2013, 09:17 PM
Clayton1985's Avatar
Idle is about 5000psi FRP.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 7 Old 02-20-2013, 02:18 AM Thread Starter
I'm holding a pretty constant FRP.
post #4 of 7 Old 02-20-2013, 04:49 AM
cbenn's Avatar
Quoted: 2 Post(s)
It's SPARTAN..
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #5 of 7 Old 02-20-2013, 03:44 PM Thread Starter
Figured it out, gauge is in KPA. Changed everything over to PSI to check and Im at just over 5000 at idle
post #6 of 7 Old 02-20-2013, 05:39 PM
Makes sense, 6900kpa=1000psi
1999 Corvette Cpe
post #7 of 7 Old 02-20-2013, 06:41 PM
WoodBoy's Avatar
You shouldnt have any problems maintaining 24,500 psi on anything under 250hp
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
