DASHDAQ question
What settings are you using to monitor EGT's? is it the egrt2, I think thats right. also, on the highway, cruising with the 310 tune, my oil is 202, coolant 197, and tranny is 175, egrt2 reads 650-750 depending on throttle position. Those numbers sound about right? 2500 rpms or so.
I'm Monitoring EGTRA i believe. 650-750 on flat ground is pretty decent temps for 2500 rpms. The 310 is a hot tune. i perfer 275 for DD. and i def wouldnt tow on the 310 to much timing advance. It will work probably get hot but everything has a limit after time.
I just double checked, Im using the same thing, EGTRA.. thanks
I run 1800 RPMs crusin my temp floats between 400-600 depending on the incline. oil 202 coolant 192 and i dont monitor tranny when bobtail.
