Leveling questions
What are the benefits of leveling, if any, and is there any negatives as far as performance and wear. Thanks
Advantages of leveling, in my opinion, is looks. You retain your factory ride quality (if you do a spacer level) and can run a slightly larger tire (some guys run 37s on leveld trucks) Also, you don't really get into having too much lift to interfere with towing anything.
As far as negatives, I personally, see none. My 05 I had was leveled on 35s and I never had any issues with reliability or performance or excessive wear. I have not leveled my 08 yet, but I do plan on going that route when funds allow. As with anything suspension related, make sure to pay attention to torque values and after a few hundred miles checking that everything is still good and tight. Or have a reputible garage do it for you. |
The only benefits are looks and fitting larger tires.
Just had my 2010 F350 leveled about 1 month ago. Benefits to me were the looks....truck sits nice and level now. I also plan to upgrade to larger tires soon.
I researched on line and talked to a few shops. There are options out there as cheap as $100 and as expensive as you can imagine. Cheap kits are nothing but a set of coil spring spacers. My advice....make sure you spend the $$$ and get a quality kit. I used ReadyLift 2.5" leveling kit which cost about $350 if I remember correct. It comes with good quality coil spring spacers and shock extension brackets so you can still use your stock shocks. It also has a track bar bracket that keeps the geometery same after lifting front end. If you just try to add coil spring spacers, I'm told that your front axle may become slightly off centered due to the new angle of the track bar. Some people just leave it and have no issues but I'm pretty anal about my truck. Also make sure you get alignement after installing any level/lift kit. I had mine installed at a local 4WD performance shop so 2.5 hrs of labor plus front end aligment....cost me about another $300 for the install so total around $600 i guess for everything. Last edited by sugelle; 02-16-2013 at 07:10 AM. |
I did the same exact thing as sugelle and added tires in my sig and couldn`t be happier.sits nice and level now
I'd like to put a leveling kit on mine, but then it wouldn't fit in my garage. I had one on my 03. But that's older technology
I bought the ready lift 2.5 leveling kit.. I think it was the SST something or whatever.. The only thing I didn't like about it, and if you look at it at certain angles, it almost looks like the back is sitting lower, but tape measure from pavement to top center of wheel well was exact same front to back. I then purchased PMF traction bars and decided to go with a bigger rear block.. I went with a 5" instead of the 4" that comes with the leveling kit
Thats how my 03 sat with the procomp leveling kit I installed. Of coarse at least you got rear blocks for yours. I ended up adding a 4" tapered block to the back. My guess was it would of been fine if I had a 1ton vs a 3/4 ton.
