Bullet Proofing Motor..What Else Should I Do? - Ford Powerstroke Diesel Forum
Old 02-13-2013, 10:12 PM
As you can see from my signature I have a 2010 F350 that I have done the following to: Mini Maxx, DPF/CAT Delete, Flo Pro Downpipe Back Stainless Exhaust, S&B CAI, Sinister EGR/Cooler Delete with High Flow Intake Elbow.
The question: What else should I consider doing to make the motor bullet proof or am I good to go?
Old 02-14-2013, 04:03 AM
You have a pretty solid footing there. Check out the 'General 6.4 Modifications' sticky in the 'General 6.4' folder.
Sent from AutoGuide.com App
Old 02-14-2013, 06:31 AM
Sounds like you got most of the areas covered. You might want to look into a cold side intercooler pipe and a ccv mod.
Old 02-14-2013, 12:17 PM
i have your same mods but i have added the cold side IC pipe, trans filter with cooler, oil filter with cooler, coolant filter with cooler, im also running 5" exhaust and mini maxx, truck runs great, love it, not much more to do unless you break a hard part, im also thinking of running the air dog 2 for the fuel.
