studded and still puking? - Ford Powerstroke Diesel Forum
Old 02-05-2013, 06:48 PM
Send a message via MSN to Strokin_4_Life
iv been running the 275 tune since i bought my truck with 30 000kms and it started puking after awhile. The truck now has 65 000kms with arp studs, both new heads and new gaskets. Drove it up to work (1000kms) and once i got there popped the hook and looks like was puking out of the degas bottle pretty good. so i just tuned it down to the 250 but havent had time yet to drive it. Does anybody still get puking after being studded?
thanks
Old 02-05-2013, 06:53 PM
Have you tryed the easy thing first and changed out your degass bottle cap? And forgive the stupid question but are you over filling?
Old 02-05-2013, 07:01 PM
My guess is that you have a bad cap. You could also have an EGR cooler issue.
Old 02-05-2013, 07:02 PM
Yes you should really check. The coolant level should be at the cold level
Old 02-05-2013, 07:06 PM
i have a full egr delete sorry forgot to mention. the bottle is pretty empty ill fill it up to the cold line when i drive it home next. and ill also pick up a cap.
any other suggestions?
Old 02-05-2013, 07:29 PM
try those first. sounds like it was either to full or bad cap. seen it happen before and it was either those things or someone didnt do it right
Old 02-06-2013, 06:53 AM
Deff a bad cap
Old 03-11-2013, 06:17 PM
was a cap. thanks guys
Old 03-11-2013, 06:32 PM
Feedback Score: 7 reviews
Gotta love an easy fix! Enjoy your truck
Old 03-12-2013, 02:21 AM
i have had mine puke after studding. egr deleted and all. Possibly cracked heads is what is suspecteded. I have replaced the cap numberous times. It is not showing exhaust gasses in the coolant. But i am getting bubbles in the degas container when i shut her down after a hard run. Mechanic thinks that it is leaking on the intake side and only under high boost. Sucks.
