Input please on tuner - Ford Powerstroke Diesel Forum
Old 02-04-2013, 09:40 AM
Finally able to buy my tuner w/dpf delete for my 08 6.4 and come to find out about all of the epa headaches going on with H&S. Was wanting the mini max. Is it worth going to a Spartan instead? I don't want to reg my truck with epa for the tunes... Also is there any way of turning off the tpms with out having a H&S tuner?
Old 02-04-2013, 11:46 AM
Either h&s or spartan will do the trick for you. I think the h&s are getting pretty hard to find and are the same price and in some cases even more than the spartan now. It just depends on what options on each appeal to you.
Old 02-04-2013, 12:00 PM
I'm only wanting to turn off the dpf, do a egr delete, adjust speedometer for tire size, turn off tpms, and turn off seat belt alarm. Main reason for doing this is to make the truck last. Really not looking to add hp.
Couch warmer
I see a lot of vendors selling the h&s for $1600-1700 right now. The spartan can be had for a bit less. Or you can go to the classifieds and try to find one cheap. Don't think you can go wrong with either one though.
Old 02-04-2013, 12:33 PM
I'm not sure if you can do the speedo adjust, tpms and seat belt thing with spartan quite yet.
Old 02-04-2013, 01:28 PM
I've never heard of Spartan getting those abilities, still think it's H&S only myself.
Old 02-04-2013, 01:30 PM
You have to buy a seperate thing also to adjust TPMS from h&s
Old 02-04-2013, 03:00 PM
Send a message via AIM to WydOpen
I have it and no regrets! It runs about $99. You can completely turn it off, or adjust TPMS pressures for front and rear, independently. Great tool, worth the money!
Old 02-04-2013, 03:11 PM
Im pretty sure you can turn of the seat belt minder by a set of steps, eg. plug in/disconnect numerous times with ign on, foot on brake etc etc..... it might even be in the owners manual, or do a search on here ive seen it before on here.
Old 02-04-2013, 03:44 PM
Yes the seat belt thing is in the owners manual. I turned mine off.
