EGR delete question - Ford Powerstroke Diesel Forum
Old 01-29-2013, 04:08 PM
Illiana Chapter Director
EGR delete question
Gonna be doing an EGR delete to a 6.4 this weekend. How much coolant will I lose when pulling it apart? I'm not sure how close it is to needing an oil change, but should it be changed as well? Just wanna have everything on hand so i don't have to make a bunch of trips for extra stuff. Thanks
Old 01-29-2013, 05:27 PM
If you put a clean container under your lower radiator hose, you won't lose much. Just eye the level when you refill it and all you may need is distilled water.
I'd do an oil change if it hasn't been changed in 5,000 miles (along with oil filter).
Old 01-29-2013, 06:25 PM
You should get close to a 5 gallon pale of coolant. Find a clean bucket and drain into it and you wont lose any.
Old 01-29-2013, 08:13 PM
Will do guys. Thanks. How big of a pain is the EGR delete? I'm use to working on 6.0's.
Old 01-29-2013, 08:43 PM
Not bad I guess, Im not in a hurry to do another one haha!
Old 01-29-2013, 08:45 PM
I'm figuring I can do the EGR and DPF delete in about 8 hours if all goes well.
Old 01-29-2013, 11:31 PM
Sic2Fiddy
More power to you, wish I had the courage to do it myself...
Old 01-30-2013, 01:18 AM
I got a guy here that does the EGR deletes for 400$ he took 3 hours to do it, with the cab on. while he was doing the EGR I was doing the turbo back exhauts. He had 3 EGR deletes lined up. All i can say im glad I did the exhaust and not the EGR. I can tell you that the small 1/4" vac lines will most likely break, minedid in a few places, I got new bulk lines and replaced them and heat guy them into place. everything works great now.
Old 01-30-2013, 01:21 AM
Sic2Fiddy
"does the EGR deletes for 400$ he took 3 hours to do it"
Where is this located??
Old 01-30-2013, 04:25 AM
EGR delete question
It's not real difficult just takes time and patience. I think I did mine in around 8 hrs, but that was almost a year ago now so I'm not 100% sure on the exact time.
Sent from AutoGuide.com App
