updated my H&S need advice - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-27-2013, 12:47 PM Thread Starter
rabbitCTSV's Avatar
Hello all, Dont know if any of you have seen my 2012 console addition to my 2008 f350, but here is a quick run down,
I travel for a living well most of the time. and when im going Im always on the internet, the last time I was gone ( Brazil ) I got everything needed to do a dig overhaul on my truck, a year ago I did the DPF delete with the H&S mini maxx, so this go around i did some supporting mods, 5" exhaust and DP with no muff ( sounds great) , sinister EGR delete with elbow, full 3" IC pipe with no crimp, as well as the 2012 console and full king ranch swap,
here is my question, after i did the mods I drove the truck, drove the same IMHO , sounded much better. then I updated the H&S to the newest update to help reduce my injector noise, more boost and so on, I notice now at idle it smells like diesel fuel very bad, I never noticed this before,
Is this from the supporting mods or the new up date ? anyone notice this from the new update? or anyone have my mods? If anything I was thinking it would have more efficient air flow and not a smell problem,
Also thinking might have an injector problem . but it would smoke all the time and it does not, it smokes much the same as it did before, but I have never had the smell issue,
any help will be great, thanks.
King ranch with the 1st 2011 king ranch console mod
20 king ranch wheels with 12.5/ 35/ 20 AT
Nav upgrade with ProBox
H&S mini maxx w/custom dash mount
external transmission filter.
external added oil filter
external coolant filter
5" diamond eye exhaust with 4" DP
IC pipe 3" with no restriction / Cleaned intercooler
Raptor Ridged 24" light bar in middle of bumper
Raptor Ridged led fog lights
title in hand from day 1
rabbitCTSV is offline
post #2 of 11 Old 01-28-2013, 05:05 PM Thread Starter
rabbitCTSV's Avatar
wow no one has done the update? does it smell like fuel?
post #3 of 11 Old 01-28-2013, 05:32 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
i have the .47 update....i assume you also did the firmware, most forget to do that....anyway I never did smell a fuel smell ever. The new tune is less smokey, even on the 5 setting you dont get much smoke....thats pretty much all i can say, im not sure what the other things could possible be.
I think im going to drop out my muffler as well....flopro sent me a muffler with my 5inch kit i think by accident so i installed it. i have a extra pipe to get rid of it though
Big_Smokey is offline
post #4 of 11 Old 01-29-2013, 01:16 AM Thread Starter
rabbitCTSV's Avatar
I did not do that, I did what its said off the website, Ill have to look into that, install the exhaust and let me know what it smells like, thanks for the response.
post #5 of 11 Old 01-29-2013, 05:30 AM
I just updated to .48 last night. Truck runs the same as before. However, I still see a cloud of smoke when I hammer on it....I run LBF on 4, due to my mods. In any case, to smell diesel is normal since you are deleted. How many miles are on your truck? What has the temp been outside (If it is cold enough, is your high idle kicking on)? If it is, you are running more fuel through it, hence the smell. If you see blue, grey or white smoke you have a problem...if not RUN IT.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #6 of 11 Old 01-29-2013, 07:33 AM Thread Starter
rabbitCTSV's Avatar
thanks for your responce, I have 180k mile of truble free driving, I did the DPF and cat delete a long time ago when my re-gens were every few hours, , I never had the fuel smell after the delete , I always made comments how is never had a bad smell. It was only after I took off the stock exhaust with delete and replaced it with the turbo back 5" system and did the latest the update , thats when I started smelling my truck, I keep my setting on 0 for the LBF. I dont like the smoke, Im just wondering if its the tune. Is it possible to go back to the older tune? andno I dont see and whiteor blue smoke at all, It runs great, the reason i was thinking I had an injector problem is because it still makes the 2300 -4000 injuctor noise, it only gets quite when i hit 4th and 5th gear, I guess because i have converter locked up and its putting a biggerload on the engine. but Is just injector noise. not abig deal, I just hate the smell of my truck trying to hook up a trailer or load my little girl im my truck when its running, I like to start it in the morning let it run for 15 min or so while im getting everything ready for the day.
post #7 of 11 Old 01-29-2013, 07:37 AM
Quoted: 48 Post(s)
you sure you didn't just do a DPF delete originally?
drunk on diesel is offline
post #8 of 11 Old 01-29-2013, 08:41 AM Thread Starter
rabbitCTSV's Avatar
1000% sure , I have the DPF and CAT connected sitting on the corner of my garge , stands about 5' tall. heavy as ****, didnt look that heavy, haha i was wrong, I did the delete by myself. not fun, but yes im sure i did them both at the same time.
post #9 of 11 Old 01-29-2013, 10:01 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
I've did my mods a long time ago. I meant u have to update your firmware first then download the new tune or it won't work. Anyway I never smell fuel just smell good ol diesel smog. as the soot isn't getting caught by dpf anymore. Yes u can go back to older tunes but I'm not sure that would make sense. Look on your mini and see what firmware number u are on. Should be 1.2.03 I think
post #10 of 11 Old 01-29-2013, 10:36 AM Thread Starter
rabbitCTSV's Avatar
Ill have to check on that, when i did my update I did what the H&S website told me to do , inserted my SD card into my computer rerote the files and upleaded them to my mini max, I know all the names have changed as far as the power levels,
