Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 11-23-2007, 02:28 PM
huhner5 huhner5 is offline
Lowering of EGTs
Well my brother is going to get the KEM programmer finally and do the strait pipe mod... he already has the mbrp dual exhaust out back.... he wants to know if he wouuld run dual 4" pipe FROM the DOWNPIPE back would that help lower egt vs just one 4" pipe back to his duals?
Old 11-23-2007, 03:00 PM
Dave Dave is offline
Obama sucks
One pipe back is plenty when you get into the 4 inch systems. Duals on a diesel are just for looks
Old 11-23-2007, 03:18 PM
richardndawnc richardndawnc is offline
I have the single 4" off down pipe, with it turned down out of a 5" tip at rear end.And my EGT dropped from 1600 up hill to 1250 on the same hill, with the same type load. It will only see over 1400 if I really push it hard up hill with a heavy load. Kem said not to let the truck go over 1400 for more than a few seconds on a heavy pull , so I do back off some and it drops instantly under 1400, not like it did in stock form ,with DPF were it would just hang there for a few seconds before it would cool down.
