I'm having problems with the Ford hubs seizing and not disengaging, which hub is best, is there others for the 08 with 6.4
Thanks |
have u checked pricing ?
all the bearings and ETC have to Be replaced I think Dynatrac has the best rep and original Idea i just keep My OEM stuff working with a little PM. I think you found the only 2 options other than the just Auto version of the PLH hubs We have now just without the Auto feature and for a FYI our OEM hubs are made By WARN |
Dealer wants $2500 to replace my 2 hubs with oem stuff, they are seized up so I don't know how to save them?
I don't know what is wrong with your truck but the actual hubs are three screws and a 20 minute job to swap ,, the Hubs can't be more than 400 + for the set
I imagine you have seals and a vacuum loss issue for that kind of money ? and since the Auto hubs also work as manuals ,, why spend the coin ? |
Hubs are $315 each, u-joints are 114 each, 2 seals at 67.95 each, 2 seals 42.92 each, 2 seals 16.68 each, 2 splash shields at 53.33 each labour 880 plus all taxes
Do you have a parts breakdown as the only problem I have is when it gets below say 20 below zero, when I go from 4 x 4 high to 2 wheel high one hub doesn't disengage and the diff spiders spin like crazy
If you deside on Dynatrac's...we are a dealer.
Stockers...A good mech thats done these a few times can do both sides in under 3 hours...easy |
Re: spyntech or dynatrac front hubs
Hell you can get the entire axle for almost $2500. I would just have them fixed.
Sent from my SCH-I535 using AutoGuide.Com Free App |
Looked on e-bay, hubs are about $150 each, may find used or just stay in 4X4 on cold days. Is there maintenance that I can do to the hubs, is it just the three screws to remove?
