Spartan Shifting - Ford Powerstroke Diesel Forum
Old 01-09-2013, 02:45 AM
Spartan Shifting
we installed the spartan 275 tune EL tune last night and i noticed it doesn't shift as smooth as stock and seems to kind of jump around when i'm getting ready to let go of the pedal after i get into it...i'm just wondering if this is normal, it isn't anything major that is going on but it doesn't seem like it's healthy for the transmission over time...is this normal for the 275 tune? is there a better tune for the transmission? my main concern is MPG, not necessarily power...
What we did: EGR Delete, DPF/CAT Delete, 5" Flo-Pro (Downpipe Back), S&B Intake, Spartan Tuner
Old 01-09-2013, 03:01 AM
Yes that is normal for the race tunes to shift harder and have a touchy pedal. You might want to try the 210 tune it shifts close to stock with more power and MPGs than stock. But the high HP tyunes will yield the most MPG.
Old 01-09-2013, 03:59 AM
I had this same problem when I installed mine. I drove it for over a year on the 300 EL tune figuring I would eventually get used to it. I finally had to purchase some new tires so I went ahead and installed a leveling kit and new rear blocks with traction bars. I can not express how much of a difference it made. It is almost like stock again. You can feel it shift firmer than stock but nothing like it did without the blocks. People used to comment on how hard it would shift but now they dont even notice. It also made the harshness of the cruise control a lot less. If you have the money for traction bars I would get a set!
Old 01-09-2013, 06:29 AM
how much are the traction bars?..and would airbags be an option as opposed to the leveling kit etc...? i was already planning on installing some at some point
Old 01-09-2013, 06:48 AM
Depends on what what kind of HP you are looking for and what you are using your truck for. Traction bars will run from $500 and up. Give Trevor a call at PMF and he will be happy to talk thru it with you and hook you up with exactly what you need...
Btw I also agree traction bars made shifting night and day!
Sent from my iPhone using AutoGuide.com App
Old 01-10-2013, 03:31 AM
X3
Traction bars make a huge difference
Old 01-10-2013, 07:51 AM
I got my leveling kit and traction bars from Jason at Newton Lifts. I would highly recommend him due to the customer service, knowledge and product he sales. I am very happy with the kit!
