new 6.4 owner have ?s on towing and chips - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-24-2012, 09:37 PM Thread Starter
I have a 2008 F350 DWD. The truck is fully stock and am not ready to get rid of DPF yet. I only put 5000 miles on the truck a year and tow about 14,000 or so Fithwheel and boat double pulling. I have been looking at getting a Spartan Chip and h&S Minimaxx. Questions are.
1. With a fully stock pickup can i run the 210 tow tun safely or do i need to do the DPF with spartan.
2. what is the more safe chip to run while towing is one have any other advantages or the other for safe operatoins.
3. What chip has less issues.
thanks
mtrain is offline
post #2 of 11 Old 12-24-2012, 09:42 PM
stroker007's Avatar
thanks
yes you can but you will have to delete the dpf to run that hot of a tune. spartan and mini max will both get the job done, mini max has shift on the fly spartan doesnt prob the only difference. they niether have issues, use the search function and look it up. they are a lot of these threads each day about tuner questions
2008 f250 ccsb 4x4 lariat.. 8 inch lift, 24in fuel hostage, 40in ss m16, Arp studs, egr delete, street diesel performance down pipe, intake elbow and cac pipe, Diesel site boots, xrt pro with kem tunes, s&b intake, 5 inch exhaust, edge cts, tinted mirror lights, pioneer 8400 double din, hid headlights and fogs, two jl audio 13tw5 with rockford 1500 watt amp, jl audio door speakers and tweeters, prestige 2 way alarm and remote start.
00 f350 lariat 7.3 cc lb. (the worker)
stroker007 is offline
post #3 of 11 Old 12-24-2012, 09:50 PM Thread Starter
So H&S would be a better choice for me due to they have the TOW tune with no added power.
Alos what would be too high of a tune for me with my stock truck with either of the chips
mtrain is offline
post #4 of 11 Old 12-24-2012, 09:55 PM
stroker007's Avatar
i believe spartan has that to. you cant go wrong with either i personally have h&s but spartan makes a good product to
post #5 of 11 Old 12-24-2012, 09:55 PM
Quoted: 45 Post(s)
My experience with the Mini Maxx and the DPF present was that it went through regen more often, especially on the higher DPF present tunes. I say if you are going to do it, do it right and DELETE. I bought mine new and ran it for a month or 2 with the DPF and knew I had to get rid of it. The truck is amazing with its unlocked potential...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #6 of 11 Old 12-24-2012, 09:57 PM
Quoted: 45 Post(s)
It's not really a tow tune per say. You just have multiple power and transmission options.
post #7 of 11 Old 12-24-2012, 10:42 PM Thread Starter
Default Power Levels
Power Levels
DPF Present
Stock HP
Mild: 40 HP
Wild: 80 HP
Hot: 120 HP
Power Levels can be adjusted on-the-fly at the touch of a button after Installing the Download to the vehicle. The current Power Level will be saved even if the Mini Maxx is unplugged.
So safey pulling would be the 40HP tune and you said on the 80 to 120 tunes i would be doing the burn cycle more often. Do you seen much increase on milage with this chip with the DPF present
mtrain is offline
post #8 of 11 Old 12-24-2012, 10:44 PM
stroker007's Avatar
yes 40hp would be ok. and you wont see an increase until you delete it.
post #9 of 11 Old 12-24-2012, 10:45 PM
Quoted: 45 Post(s)
Not at all.
post #10 of 11 Old 12-24-2012, 11:14 PM Thread Starter
Do you have to delete the Cat also
mtrain is offline
