Newby with questions on performance mods - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-16-2012, 01:23 PM Thread Starter
Ok a lil background, first time diesel owner. 2008 F250 ext. cab 2wd. I just installed a H&S mini and an AFE stage 2. I am looking for some tune suggestions for mileage and performance. Is there a good mix of setting that work the best.
I may sound like an idiot asking this but what does the mini mean be defuelling? Is it restricting the amount of fuel?
What exhaust is better to go with? I was thinking 5" and deleting everything. I just don't know if I should go Flo Pro, MBRP, etc.
kmack08 is offline
post #2 of 9 Old 12-16-2012, 01:28 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
If you can keep your foot out of the throttle you will get the best mileage on the highest HP tunes.
As far as exhaust, go with the 5". These trucks aren't loud even with straight pipes and the 5" gives a deeper rumble than the 4".
Sent from my iPhone using AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 9 Old 12-16-2012, 02:07 PM Thread Starter
Keeping my foot out of the throttle is going to be the hardest thing to do!!
kmack08 is offline
post #4 of 9 Old 12-20-2012, 02:50 PM Thread Starter
Will going with the stock down pipe be ok over upgrading it turbo back? Will it make a big difference in power? Or just a tone difference?
kmack08 is offline
post #5 of 9 Old 12-20-2012, 03:45 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
The down pipe won't be noticeable power wise unless your laying down some power. The hassle of removing it and only real gain is lower egt's it isn't that worth it if all your doing is going for a reliable truck. Down pipe back will do ya just fine.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 9 Old 12-21-2012, 04:52 AM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
When you go into defuel mode because you have surpassed one of your set defuel parameters, the truck will cut power slightly to bring your temps down below your set points.
4" exhaust is plenty, but the 5" sounds better. NO muffler needed on either. These trucks are quiet. You dont need an aftermarket DP, but like travisH3 said it will lower your EGT's even further. I found adding the DP worth it. I didnt add it until after I did my DP back exhaust. It only took about 40 minutes to install and was little to no hassle as long as you know you know your way around a ratchet and sawzal.
Exhaust brands are all pretty similar. The fit and finish of the big names are all pretty good. I have a flo pro exhaust, with an AFE DP. Most people have had good luck with flo pro, diamond eye, and MBRP. All depends on how much you want to spend.
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #7 of 9 Old 12-21-2012, 05:28 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
take the lid off of your afe intake box...you'll hear the turbo working better, you can thank me after you test this out
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #8 of 9 Old 12-21-2012, 06:43 AM Thread Starter
I haven't heard anything bad about the flopro yet. I think I am going to go the 5" and do dp back. I was thinking about the egr delete too. Should I trust the H&S to turn it off so I don't have to do the delete?
kmack08 is offline
post #9 of 9 Old 12-21-2012, 06:48 AM
You can trust the H&S to turn the egr off, but that will still leave your coolers in place which can still fail over time. Its all up to you. I ran my truck with the EGR disabled until I got out of warranty, then I did the full delete. Putting an EGR and coolers back on the truck is a real pain in the arse.
SOLD:
