Local shop says I don't need to stud - Ford Powerstroke Diesel Forum
Old 12-16-2012, 11:10 AM
My current setup - 08 6.4 - I have a 5" flow pro pdf/cat delete, egr delete with the elbow, H&S mini max, and an s&b intake. Advanced diesel, my local diesel shop (that's all they work on) says that I don't need to stud my heads even for a piece of mind. They are an H&S dealer and installer and are very mod friendly and experienced. He said in all their years of being in business working on all models and years of the big three that the 6.4 he talked very highly of for being a really strong base. They did my egr delete and knows that I'm making my truck really reliable. I e been talking to him about studding my heads for piece of mind and preventative maintenance. He had me come into his shop about a month or two ago to look at a 6.4 that is the ONLY one that they've worked on that had a leaky head gasket. Not even blown. He was studding it at the time. The guy towed heavy farm equipment every day and did truck pulls etc. he said that that guy pushed his truck and if there was a weak link that guy would find it.
They said they stud 6.0s all day long which I knew of and said the 6.4s heads are 8lbs heavier of material than 6.0s and showed me the stud size differences between the two. Which I knew the 6.4 was a little more stout. Anyways he said he could do the studding if I wanted but after doing the deletes I could run on 300hd and not have an issue with the hg. He is that confident in the motor, as long as I'm not driving like a complete idiot at every stop light.
However, studding would still make me confident as for bullitproofing along with coolant filter and fuel/water seperator.... What do you guys think? He said he could stud it for just over 1k
Old 12-16-2012, 11:16 AM
Illiana Chapter Director
If you can afford it and makes you feel better about the truck reliability, do it. I guarantee if I owned a 6.4, that would be on the top of my to do list.
Old 12-16-2012, 11:29 AM
for 1k i would do it. no hg are safe. they blow on stock trucks. if you run the hd300 tune your a ticking time bomb of when the hg will go. it could be 50k miles or 500 miles but eventually they will let loose
Old 12-16-2012, 11:34 AM
Where is he that he can do it for a grand?! I'll be there tomorrow to have him do my truck!
Sent from my iPhone using AutoGuide.com App
Old 12-16-2012, 11:45 AM
Nw Indiana. Just over a grand. He said lately he hasn't been using arp due to back order. He is using another brand just as good he said. I can't remember the brand but he said there are pro racers etc that use this other brand. It's with the cab off too. I'm prob gonna do it for the piece of mind to run any tune I want without any problems, after Xmas of course
Old 12-16-2012, 11:47 AM
i would only use arp. tthey are proven to last. 1k is super cheap
Old 12-16-2012, 11:53 AM
Ya I would so arp or nothing also.
Old 12-16-2012, 11:56 AM
Ok, I'll keep that in mind. Hopefully when I'm ready they won't be on back order. That was a little while ago, so maybe now they're not.
Old 12-16-2012, 01:59 PM
If you can afford it do it. A quick google search will inform you that blown head gaskets happen quite a bit on the 6.4. They happen on tuned trucks and they happen on stock trucks. Mine have had to be done twice. Both times running a mild tow tune and I never beat on my truck. The reason for the second time is a shop screw up the heads were not checked.
Old 12-16-2012, 03:38 PM
Where at in NW Indiana? I am in Valparaiso (Wanatah to be exact). I am very curious about this as well.
