Safe defueling settings
Just looking for some advice on defueling settings. What are your thoughts for safe low power settings. I am running mini max on easy.
Mine are:
Ect cold 160 Ect hot 220 Eot 220 Trans 190 Boost 38 Egt 1350 |
Thanks. I have mine set pretty much the same. Can you explain to me the low boost fueling? I understand that it Meens more fuel at low boost. 0 least smoke 5 most smoke. Can you hurt anything buy running this at 0? What are you all running it at?
You wont hurt a thing running it on 0. It just means that the fuel wont come on as hard until your truck starts making boost. Alot of guys are running in the 1-2 settings.
I run mine on 2. I use to run on 4 but gets hot too fast.
I run mine at 1. Running at 0 won't hurt anything. You'll just have the least throttle response. Other than that it will be fine.
I believe i am running mine on 2.
