Just programmed now white smoke - Ford Powerstroke Diesel Forum
Old 12-12-2012, 03:32 AM
Just installed CAI, 4" flow pro down pipe back, mini max. When I back off of the throttle it is blowing a thin haze of white smoke that is hard do even see. I am running the easy tune in mild. Any ideas?
Old 12-12-2012, 03:39 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Did it just do it once, or is it all the time? Could the white smoke actually be light grey since it is so light? Make sure you arent using any coolant, that would be my first guess, after that it could just be a little water vapor burning off since none of the filters are in place now.
Old 12-12-2012, 03:47 AM
Every time and yes it could be grey I was out for the first test run and noticed it when I got home I backed into the garage and reved it up and it wouldn't do it. I am going to watch the coolant and I am starting egr delete right now
Old 12-12-2012, 04:28 AM
Have fun egr deleting. I thought I had all kinds of things wrong with mine after I did my stuff. I was just paranoid . Waiting for the worst.
Old 12-12-2012, 05:16 AM
Big smokey how is everything going since deletes and tunes?
Old 12-12-2012, 05:24 AM
Good luck with the egr delete. Take your time, its not that hard.
Old 12-12-2012, 05:55 AM
Thanks. The only things I have questions about are where the coolant plugs go and what hose the instructions are telling me to reroute back to the degas bottle with the hose connector they gave me? Did you do a waste gate?
Old 12-12-2012, 06:08 AM
The hose will be your smaller vent hose as I call it on the top. You will know what hose once you have everything on the truck. It will be a smaller hose left over with no place to plug in except the degas bottle. As for the coolant plugs, one goes up behind the fan on the block where the vertical cooler was, the other is on the timing cover. It is pretty straight forward. The plugs go where the steel coolant lines used to plug in at. I do not run a wastegate and have never had issues.
