updating my xrt pro
I am trying to update my xrt pro and it tells me to remove the sd card and such. problem is. no SD card on mine. just a place to plug in a usb cord and the OBD cord.
I am guessing I have an older model, but is the download program still valid for this tuner? |
go to hsperformance.com down load the updater, and plug your tuner in and see what it says. it may just update the way it is. wont hurt anything, if anything it will update or say no sd card. in that case i would call h&s, they have great customer service even through all these EPA problems
ok I'll try it. just didnt want to screw the programmer up
is this just an older model?
It's a micro sd card, very small, it barely sticks out and you have to push in on it for it to pop out, or maybe they did make one without a card???
definitly no card
Does it look like this?
The little tiny slot under the mini usb port is where it should be: ![]()
no it doesnt look like that
Must be an older revision then, you'll probably have to get ahold of H&S like Travis suggested.
apparently there was an xrt first then an xrt pro. not sure what the differences are
