Egr delete questions. Please help!!! - Ford Powerstroke Diesel Forum
Old 12-07-2012, 10:14 AM
1.where can I find the best instruction or video of installation?
2.I watched a video of someone putting a copper sealant on block off plates and I am wondering if it's necessary?
3.is there any tips or tricks that would make the removal of junk and instillation of block off plates?
4.what tools do I need to complete the project?
Old 12-07-2012, 10:21 AM
5. How much coolant does my tRuck hold?
6. Is the coolant mixed with water or is it straight coolant?
Old 12-07-2012, 10:26 AM
Also, I am installing mini max. Cai. 4" flow pro down pipe back exhaust. And egr delete kit. Any suggestions or tips would be greatly appreciated
Old 12-07-2012, 12:27 PM
Do not do straight coolant.. Mix 50/50. Where you at?
Old 12-07-2012, 01:29 PM
1. There are links on here for EGR deletes on 6.4 that work great... search for them (sorry, I don't have the link on hand). Google Sinister's EGR delete kit instructions. They are slightly better than the ones for Flo-Pro.
2. I didn't and mine doesn't leak. You could if you wanted to I guess.
3. Patience. Taking the vertical cooler out will require some twisting and a little bit of grunt power. The horizontal one will take longer but can be worked through the spot where your battery box was.
4. Wrench set, a few deep sockets, a few extensions for 1/4" and 3/8" drive (3, 6, 9, and 12" would be great).
5. 5 gallons of mix is what you'll need, maybe 1 or 2 more... but 8 gallons of mix for a full refill. If your coolant looks good coming out, make sure you're draining into a clean container. You can reuse it until you do a full system flush.
6. Mix.
Old 12-07-2012, 03:39 PM
Thanks guys I really appreciate all the help.
Old 12-07-2012, 04:40 PM
deep sockets small sets....gear wrenches worked really well for me. there is an awesome write up on here for our trucks with pics. thats what i used. the rest you just have to figure out. its tricky if you are like me and wasnt tooo familiar with all the parts
Old 12-08-2012, 03:35 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
EGR Delete-Full Install (Long+Pics)
That is a pretty good write up that clayton did I believe. It really isnt to hard if you take your time and have a second set of hands available when its time to pull the coolers. Took me about 7 hrs with plenty of pizza and beer breaks.
Old 12-08-2012, 06:31 PM
Ok I have looked and read the link above and it is pretty straight forward but I am just installing the egr delete kit without the elbow For now I did not do enough research before I ordered I am going to order the elbow ASAP my questions that I still have are:
1. I need to know exactly where the block off plates go???i think that one exhaust block off plate goes where the lower(horizontal) cooler bolts to the exhaust manifold flange. I think the other exhaust block off plate mounts to the intake where the top(vertical) cooler is bolted to.
2.where do the two coolant plugs go??? I am having trouble pin pointing exactly where they go
3. When installing new exhaust manifold bolts instructions say to torque to factory specs should I tighten them real tight or go buy a adjustable torque wrench if so what is factory specs
4. Not sure where to install the hose connector or what hoses that it is connecting
Old 12-08-2012, 06:37 PM
May I ask why to use 50/50? Is that the red one!?! I use the red one and never put water is it ok?!
