EGR cooler delete with stock programming - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-01-2012, 01:25 PM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
Can you delete the EGR coolers on a 6.4 (leaving the valve/housing in place and plugged in) on the stock programming with no drivability or reliabilty concerns?
I've done some searching and can't seem to find a definitive answer. I am aware that a P0401 insufficient EGR flow DTC will illuminate the check engine light but other than that will anything else happen on bone stock tuning?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #2 of 13 Old 12-01-2012, 05:36 PM
Doss's Avatar
Quoted: 18 Post(s)
Do you mean without a tuner? If so, not that I know of.
If you mean with something like a Mini Maxx, then you could just leave it on No Power (essentially stock tuning) and they aren't needed.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #3 of 13 Old 12-02-2012, 05:50 AM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
yes without a tuner. just the coolers deleted, EGR valve still plugged in, DPF still in place. I don't care about the check engine light, all I need to know is if driveability will be affected
-Matt
2015 F-250 XLT 6.7L
post #4 of 13 Old 12-02-2012, 05:52 AM
superduty6.4's Avatar
I would think that it would go into limp mode. Don't know that for sure though.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #5 of 13 Old 12-02-2012, 10:19 AM
Doss's Avatar
Quoted: 18 Post(s)
I'm with superduty6.4. I think it'll go into limp mode if something major like EGR is "broken."
I'm not 100% though. You could try it and let us know. LOL
Doss is offline
post #6 of 13 Old 12-02-2012, 10:57 AM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
I've had a few trucks in the past that had EGR codes stored in them with no driveability issues. Never ran into a P0401 (EGR insufficient flow) on a 6.4L though so I'm unsure of what it will cause. Typically the EGR system on a 6.4 doesn't get plugged up.
I may have to try it. There are quite a few EGR cooler delete kits on ebay and none of them mention running a tuner.
-Matt
2015 F-250 XLT 6.7L
post #7 of 13 Old 12-02-2012, 11:05 AM
All the EGR delete kits will require a tuner to properly delete them however to run EGR delete tuning you would have to also delete the dpf. I don't think there are any tuners that would only delete the EGR and leave the dpf intact.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #8 of 13 Old 12-03-2012, 06:29 PM
I dont see why you couldnt guys run the blocker plates without a tuner
Truckless
Garett742 is offline
post #9 of 13 Old 12-03-2012, 06:32 PM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
I've been getting a rash of 6.7s with plugged EGR coolers and they don't do anything in the ways of derated power or limp mode. They all run fine with just a check engine light
If I get the go ahead I'm probably going to try this on a 6.4.
-Matt
2015 F-250 XLT 6.7L
post #10 of 13 Old 12-03-2012, 07:50 PM
Doss's Avatar
Quoted: 18 Post(s)
The problem is, your EGR is still getting clogged up. Look at pictures of what the EGR looks like even after 50,000 miles and you'll probably want to delete the whole thing.
Doss is offline
