Anyone have dyno numbers on latest tune from H&S? - Ford Powerstroke Diesel Forum
post #1 of 35 Old 11-29-2012, 08:25 PM Thread Starter
dt23400's Avatar
Just what the title says. wanting to know what changed in the last update on the tune. used to hit 48 psi on wot now it at 40. this is the hd300 tune. still moves but im just wondering why the change and what kinda power they are making on this tune. wont hit a dyno till next year some time. probably summer with other mods.
2005 rclb 6.0 f250
372k 4inch exhaust sct x4 stock tunes 54 ficm
2002 gtp precision t62 turbo zzp turbo cam zzp tranny 65lbs injectors 505whp 25psi
2006 sti stage 2
dt23400 is offline
post #2 of 35 Old 11-30-2012, 07:13 AM
Doss's Avatar
Quoted: 18 Post(s)
On the HD300 tune (with intake and delete pipe), you should be making mid-500 HP and between 1000-1150 lb-ft at the wheels.
I don't know exactly how much this would drop over a loss of 8 lbs of boost, but I'm also not too sure how efficient the turbos are over 40 psi either.
Maybe that helps a little... maybe not.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #3 of 35 Old 11-30-2012, 07:17 AM Thread Starter
dt23400's Avatar
mostly looking for a dyno run or something because i know before people were laying down to the higher end of 5s. just wanna see the difference in power since the new tune. i thought i may have read somewhere on the h&s forum that it made more power. could be wrong tho. cant find anything solid. thanks tho
2005 rclb 6.0 f250
2006 sti stage 2
dt23400 is offline
post #4 of 35 Old 11-30-2012, 07:18 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Im with Doss. I dont think the loss of boost will hurt you. Im sure the turbos lose efficiency after 40+. After that you would want to look into upgraded turbos.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 35 Old 11-30-2012, 07:36 AM Thread Starter
dt23400's Avatar
im not disagreeing at all i just want to see numbers and know the reason they changed it.
2005 rclb 6.0 f250
2006 sti stage 2
dt23400 is offline
post #6 of 35 Old 11-30-2012, 12:37 PM
strokin07's Avatar
Sickstroke6.0 laid down 577 with hd300 and intake exhaust and I think he has 35s. Idk which tune version that was though. It was recently though.
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #7 of 35 Old 11-30-2012, 01:52 PM
smotrs's Avatar
But was that on the latest update our a previous update. OP wants to know about the recent update.
Sent from my LTEVO using AutoGuide app.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #8 of 35 Old 11-30-2012, 02:09 PM
strokin07's Avatar
Im not sure sorry. I just did a 40-95 roll with the new hd300 and saw 42 but it was little downhill. If I roll into it on the hwy in 5th I can see 46-47 psi.
2008 F-250 KR
7" ICON
7" PMF blocks
22x14 Fuel Octane
37" Toyo M/T
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
post #9 of 35 Old 11-30-2012, 02:40 PM
strokin07's Avatar
That tune was updated on november 2 so whatever one that is.
2008 F-250 KR
7" ICON
7" PMF blocks
22x14 Fuel Octane
37" Toyo M/T
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
post #10 of 35 Old 11-30-2012, 03:07 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
I can hit 43 on the 250 tune.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
