4800# coils up front & block removal out back
I wanted to lower my 2010 CCSB a smidge to help with access into the garage, ingress/egress and overall look. I'm running stock tires and stock 20" rims.
I found a set of 4800lb front coil springs on eBay for super cheap. I'm planning on removing the factory block in the rear as well. For those who have done this, is there enough thread on the ubolts and is it ok to reuse the ubolts? Should I cut down the bump stops or are there some aftermarket ones I can get that are a little shorter? Oh and one more question - is this change enough to warrant a trip to the alignment shop? Thanks! -Mike Last edited by MikeSherman; 11-29-2012 at 05:11 AM. |
You will need shorter u-bolts. I would also trim down the front bump stops some as well. You shouldn't have a problem with the rears. When I did 4400lb springs and no block, I didn't need an alignment. The steering wheel was also fine and didn't need any adjustment. I could have just been lucky though.
Good Luck. |
I never once experienced death wobble. My truck rode amazing with 5.4L front springs. I also made quite a few passes at the drag strip with that setup. Cut a 1.66 60 foot with a real stable front end. Only time I had issues was launching above 18 psi. |
I'll keep my stock springs in case I'm not happy with the 4800# springs. Thanks for the info, guys! -Mike |
I have some. I'll measure them later for you.
I appreciate it, Jeff! Thanks.
...nothing worse than diving into a DD weekend project and realizing you need to put everything you just took off back on because you didn't have all the parts to begin with!! -Mike |
also interested in doing this to my 08. figured lowered on 20s with 33s or a tad smaller would look cool and handle decent. with some sweet shocks i think itll be awesome.
I did some more searching and found the size of the Ubolts: 5/8" x 3-5/8" x ?? Long
The most accurate approach for length will be to measure the ones on my truck once I get it back from getting a bedliner sprayed in and tonneau cover installed. At least it was brought to my attention that I needed new Ubolts before I started the project! I'll probably just order from these guys: Leaf Spring U-Bolts, www.ATSSPRINGS.com Thanks. -Mike |
Jeff, it depends on what conditions you were looking for when assessing the death wobble. Mine rides fine 99% of the time but when taking a high speed turn that is slightly bumpy (we have an interstate turn here on a bridge with huge expansion joints) my front end gets a little sketchy. It pretty much goes straight and shudders hard. To alleviate this, I normally take some angle out of the turn by running wide and hitting the worst joints while driving straight.
I'd be interested to see how the truck looks lowered just a little bit on 20's. I drive into a few parking garages every now and then and if they say clearance is below 7 feet, I just get out and walk. |
