Dpf reinstalled after delte seeing code p0404 now??? - Ford Powerstroke Diesel Forum
Old 11-27-2012, 07:55 PM
Had the mini maxx and delete pipe on for probably 5k now I reinstalled the dpf and left the mini in drove it for 10 mins and code p0404 came on twice now I googled it says somthing about the egr. Is it stuck? I plan on taking the dpf off next week after I get this fix it ticket signed off should I be worried? Thanks guys not sure if I should have put this in the right section sorry if I didn't!
Old 11-27-2012, 08:31 PM
Powerstroke Techie
Feedback Score: 8 reviews
I've done 3 of these get a new egr valve! It's burned up!
Old 11-27-2012, 09:06 PM
Do I have to replace it if I'm going to delete again? Won't the mini turn it off?? Is it ok to drive in the mean time?
Old 11-27-2012, 09:08 PM
It's still under warranty should I bother with dealer while its in stock form?
Old 11-28-2012, 03:42 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
If you still have a warranty I would replace it. Even if you delete it, at least you know you have a good working EGR to put back on if need be.
Old 11-28-2012, 04:32 AM
Good advice....Put that new EGR in a safe place for later....Who knows what is going to happen with emmisions in the fututre.
Old 11-28-2012, 07:26 AM
GRI GRI is offline
did you reset the mini maxx so it is at the dpf on tunes? or did you leave it on the dpf deleted tunes. you do have to switch it back to dpf on.
Old 11-28-2012, 07:30 AM
Yes I switched it back right away to the dpf present tunes... When I got home last night I loaded the oem tune ill see what happens with oem tune today... When I take it in to the dealer do you think they're going to hassle me because of it being deleted?
Old 11-28-2012, 07:47 AM
Is it safe to drive like this?
