Unable to communicate with ECU - H&S XRT PRO - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-15-2012, 07:58 AM Thread Starter
NobleX13's Avatar
I have a 2008 F280 6.4L and am trying to install my new XRT Pro but get stuck at the "Key Run" screen when trying to perform the initial dump from my ECU.
Is there anything I should try besides spraying contact cleaner on my OBD-II port? I tried to connect another tuner (SCT Livewire) and it cannot read from the vehicle either.
Does anyone here have the part number of just the OBDII/Data port, without the harness?
Thanks.
NobleX13 is offline
post #2 of 6 Old 11-15-2012, 09:13 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Hopefully you aren't having the same problem mine is. Mine was shutting down the ecu so the tuner wouldn't connect. Is it throwing any codes on the truck? Mine was returned to stock and now at ford. Is the tuner freezing or is it letting you do anything?
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 6 Old 11-15-2012, 10:05 AM Thread Starter
NobleX13's Avatar
I can't get the tuner to do anything. The truck has never, ever been flashed and I can't even read the codes from it. Zero communication with the ECU.
NobleX13 is offline
post #4 of 6 Old 11-15-2012, 10:19 AM
travisH3's Avatar
Quoted: 2 Post(s)
thats what mine did. does it start and drive fine or will it not start?
T-rav
2010 F350 6.4-
travisH3 is offline
post #5 of 6 Old 11-15-2012, 10:27 AM Thread Starter
NobleX13's Avatar
It runs, drives, and performs fine; I just can't communicate with it via the OBDII port. This was a former fleet vehicle of the DHS and it has its share of quirks. I am tempted to take it to the ford dealer next week, although it's out of warranty.
NobleX13 is offline
post #6 of 6 Old 11-17-2012, 07:07 PM Thread Starter
NobleX13's Avatar
Good news! I got this sorted out. After poking around under the dash I noticed a tan wire in my primary wiring harness that was cut. After performing an in-line soldered splice I was able to communicate with the ECU and tune my truck. Thanks guys!
NobleX13 is offline
