ERG delete needed with H&S Mini - Ford Powerstroke Diesel Forum
Old 11-13-2012, 03:20 PM
From my understanding the H&S mini does a computerized ERG block off. If so do I really need to do an ERG delete?
Old 11-13-2012, 05:46 PM
You don't need to physically remove the egr & coolers but doing so eliminates the possibility of something still failing like the coolers rupturing for example.
Old 11-13-2012, 08:18 PM
A lot of work is needed to do that so I was wondering. I might wait until I do head studs when the factory warranty runs out in February.
Old 11-14-2012, 03:58 AM
If you were planning on lifting the cab to do studs then the egr delete would be a ton easier to do.
Old 11-14-2012, 04:15 AM
Just curious if you already have your H&S mini??? If not, I'd come up with a plan "B"...
Old 11-14-2012, 06:06 PM
I do, along with a tuner (H&S mini), exhaust, and intake.
Old 11-15-2012, 03:14 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Most vendors still have many in stock. In a month or two they will become hard to find but there is still time to get an "offroad" tuner.
Old 11-15-2012, 04:57 AM
along the lines of EGR's, does the plate(s) totally eliminate the concerns too? I mean, without removing the 50 pounds of hardware, do the block off plates (which I understand are easy to install) eliminate the issue of possible cooler ruptures?
I know.. stupid questions.. But, I gotta get a grip on this truck before I start working on her..
Old 11-15-2012, 06:08 AM
No. With the block of plates it just stops the exhaust gases from flowing in the coolers. The coolers will still flow hot coolant. Its best to take off the coolers also and replace the intake elbow
Old 11-16-2012, 12:29 PM
All the tuner does is stop the EGR valve function, with out physically removing the EGR system there is no way to prevent the failure of it. The valve being disabled just prevents the exhaust soot from reentering the motor. The coolers will still have exhaust flowing through them and dead heading into back side of the EGR valve, as well as coolant flowing through them as well.
