mini max ? s - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-03-2012, 09:57 AM Thread Starter
Deathfly's Avatar
mini max ? s
I know you don't have to have sensors installed on the delete pipe to run the mini max. But I can buy a dpf delete pipe with bungs for very cheap. Can I install the sensors on the delete pipe with the mini max or should I try to plug them somehow? Any advice?
Second question I'm looking at an used mini max to purchase. Do they need unlock codes or do I need the h&s dealer to unlock it or something. I want to make sure if I purchase a used one I can just plug it in and play.
2008 f250 CCSB FX4
Deathfly is offline
post #2 of 16 Old 11-03-2012, 09:59 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
get some bolts that screw in the holes
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 16 Old 11-03-2012, 10:20 AM
superduty6.4's Avatar
I ran mine in my delete pipe with no issues until I got my 5" exhaust.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 16 Old 11-03-2012, 01:15 PM Thread Starter
Deathfly's Avatar
For bolts to screw in the holes, do I actually need the sensor plug bolts or do you have recommendation On what size fits them?
Or if I keep sensors in delete pipe dose that interfere with function of the mini max?
Also any guidance in what to look for or ask about when buying a used mini max?
2008 f250 CCSB FX4
Deathfly is offline
post #5 of 16 Old 11-03-2012, 01:48 PM
Not to sure about the bolts but I had no issues leaving the sensors in the delete pipe.
Ensure that if you are buying used the original vehicle that it was installed on is returned to stock.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #6 of 16 Old 11-03-2012, 02:26 PM
strokin07's Avatar
yes you can run the sensors without a problem. I do
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #7 of 16 Old 11-04-2012, 06:32 AM
wired1's Avatar
the bolts are metric and afe or someone was selling the 3 of them in a kit to plug the holes. Or you could just weld them closed if you don't need them.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #8 of 16 Old 11-04-2012, 07:14 AM
I will have to agree with the bolts. But if you are buying the mini max used make sure it is unlock (orginal owner turned his truck back to stock) or it cost around $500 to get the mini max unlocked.
schnet1 is offline
post #9 of 16 Old 11-04-2012, 03:02 PM Thread Starter
Deathfly's Avatar
Will do thanks for the guidance.
2008 f250 CCSB FX4
Deathfly is offline
post #10 of 16 Old 11-04-2012, 06:12 PM
deamsphelps's Avatar
deamsphelps is offline
