P012F Code - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-02-2012, 05:46 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
P012F Code
Why will my truck not throw the P012F code (delta temperature too high) with a Spartan tuner on? I need this code to get it fixed under warranty. And I'd rather not put it back to stock.
I usually run the 300 LL but it won't code on STOCK NO DPF either.
sjl2725 is offline
post #2 of 10 Old 11-02-2012, 06:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Can you hook up a trailer and see if it will throw the code? It should then if the oil cooler is plugged.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 10 Old 11-02-2012, 06:32 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
It wont throw the code with the Spartan tuner on it. To remove the tune means reinstall the dpf...
sjl2725 is offline
post #4 of 10 Old 11-02-2012, 06:38 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Either way for it to be fixed under warranty dont you have to go back to stock or are you out of warranty?
08 F350 cc/sb 4X4
post #5 of 10 Old 11-02-2012, 06:49 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Youre gonna have to reinstall the DPF for the warranty repair anyway
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 10 Old 11-02-2012, 07:04 AM
Quoted: 6 Post(s)
I know it under warranty but thought this might help: Bullet Proof Oil Cooler System, 2008-2010 F-Series, 6.4L Half-Kit
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #7 of 10 Old 11-02-2012, 09:19 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
They won't warranty the oil cooler unless there is a code. Last time, I slapped the emissions stuff back on it and threw the code in 20 minutes.
I just got back from the dealership and the diesel tech says its ok. 240-250 towing for short periods is ok. If the oil cooler was clogged, I'd be hitting 270+ and then there is an issue...
So as I said in the other thread I subscribed to, I am done worrying about the damn thing for a while. Putting Oil Cooler on after lunch for extra insurance!
sjl2725 is offline
post #8 of 10 Old 11-02-2012, 10:24 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I have towed a lot of weight in the summer and the highest i have seen my EOT go is 220. The fan should come on around 220 and cool it off quickly. Also you dont mean your changing the oil cooler right? That is not something that can be done quickly and easily.
08 F350 cc/sb 4X4
post #9 of 10 Old 11-02-2012, 10:33 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
Oops. Meant Coolant Filter.... Actually I have a 9000lb lift/grease rack in my shop . I could do the job, but just rather not mess with it. No time.
Thanks for catching that!
sjl2725 is offline
post #10 of 10 Old 11-05-2012, 10:42 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
mine also... towing in the summer up grades it has topped at 226... but quickly drops to 204 or so after the hills
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
