Stroker Long Block
Looks like I am in the market for a new engine...... 50,200 miles on the original short block....
Who makes a bullet proof engine / longblock? I run the spartan 275 as my DD tune.... Thanks Mike |
Rudy's Diesel
Stock is pretty bullet proof. Guys are making 1,000 HP on stock bottom ends. It typically takes some sort of catastrophic failure for there to be a need for a new short block.
What was the failure? Piston? |
The truck sounds awful and is throwing a bunch of misfire codes..... Very low boost when I limped it back. Thanks for the info! Mike |
Damn... sorry to hear that.
Ben and Nick form North East Performance Diesel confirmed the engine is junk.
Looks like # 1 and 8 have lost the pistons, either a rod issue or something....... At this stage, it does not make sense to tear into the engine to diagnose. Going to talk with Aaron from Rudy's tonight.... GULP Mike |
I just had the EXACT same thing happen, should have the truck back this week. My number 8 piston was cracked clean in half but did not do any other damage.
That stinks!!! Did you just rebuild or a new short block?
Will bullet proof pistons and rods solve problems like this?? Mike |
All I had to do was put a piston, rod, bearing and injector in.
So what's causing this, stuck injectors and hydro-locking? If so, what's the best way to prevent it from happening, or is it pretty much luck of the draw?
